INSTRUKCJA KODOWANIA NCS EXPERT / NCS DUMMY
Oprogramowanie, hardware, kodowanie, diagnoza, FAQ. inpa, ncs, nfs, winkfp, dis, sss.
Moderatorzy: Din76, nerwus, dziqsek
Postprzez bmw-power » 01 Gru 2014 12:34
INSTRUKCJA WEDŁUG ZALECEŃ NCS DUMMY I BMW CODING TOOL
PLIK / WCZYTAJ
REVTOR LUB EXPERTMODUS / OK
F1 / F3
MODEL / OK
GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK
WSTECZ
F4 CZYTAJ ECU / WYBIERAMY MODUŁ DO KODOWANIA
WYSKAKUJE MODUŁ KTÓRY CHCEMY KODOWAĆ / OK
ZAMYKAMY OKNO NETTODAT.TRC
NCS SKOPIOWAŁ FSW_PSW DO PLIKU.TRC W C:/NCSEXPER/WORK
URUCHAMIAMY NCS DUMMY
MODEL SAMOCHODU
LOAD FSW_PSW.TRC
FILTER MODULES BY TRACE FILE
FILTER
W POLU WYSZUKIWANIA ZAZNACZAMY "v" WSZYSTKIE OPCJE, TE PO PRAWEJ / ODNAJDUJEMY ŻĄDANE FUNKCJE / ZAZNACZAMY CO CHCEMY WŁĄCZYĆ LUB WYŁĄCZYĆ
KLIKAMY EXPORT FSW_PSW.MAN
W TYM MOMENCIE DANE ZOSTAŁY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN
NIE ZAMYKAJ NCS DUMMY ZANIM NIE WCIŚNIESZ W NCS EXECUTE JOB, PONIEWAŻ NCS DUMMY AUTOMATYCZNIE PRZY ZAMYKANIU OPRÓŻNIA PLIK.MAN
MOŻNA GO ZAMKNĄĆ ZANIM SKOŃCZYSZ W NCS TYLKO TRZEBA WCISNĄĆ CANCEL
WRACAMY DO NCS I WCISKAMY/ZMIEŃ ZADANIE / SG_CODIEREN/ OK
WYKONAJ ZADANIE
GOTOWE
JEŚLI CHCEMY JESZCZE PRZEKODOWAĆ JAKIŚ MODUŁ KLIKAMY ZMIEŃ ECU I RESZTA ANALOGICZNIE
PONIŻEJ DRUGI SPOSÓB JEDNAK BARDZIEJ SKOMPLIKOWANY
1 - FILE / LOAD PROFIL
2 - REVTOR LUB EXPERTMODUS / OK
3 - F1 / F3 / MODEL / OK
4 - GŁÓWNY MODUŁ PRZEZ KTÓRY SIĘ ŁĄCZYMY / OK
5 - BACK
6 - F4 PROCES ECU
7 - MODUŁ KTÓRY CHCEMY KODOWAĆ / OK
8 - OK
9 - F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK
10 - KLIKAMY OK JEŚLI WYSKOCZY BŁĄD ZMIENIAMY POZYCJĘ CBD NAME O JEDEN NUMER W GÓRĘ / OK
11 - URUCHAMIAMY NCS DUMMY
12 - WYBIERAMY CHASIS NP: E65
13 - WYBIERAMY NAZWĘ NASZEGO MODUŁU Z PUNKTU 10
14 - LOAD FSW_PSW.TRC
15 - ODZNACZAMY FUNKCJE KTÓRE CHCEMY WŁĄCZYĆ / WYŁĄCZYĆ
16 - KLIKAMY EXPORT FSW_PSW.MAN
W TYM MOMENCIE DANE ZOSTALY PRZESŁANE DO C:/NCSEXPER/WORK DO PLIKU FSW_PSW.MAN
16 - WRACAMY DO NCS I WCISKAMY / EXECUTE JOB
W RAZIE JAKICHKOLWIEK PROBLEMÓW ZAWSZE MOŻEMY PRZYWRÓCIĆ ORYGINALNE USTAWIENIA MODUŁU WYKONUJĄC KROKI 1...10
NASTĘPNIE WCHODZIMY DO C:/NCSEXPER/WORK OTWIERAMY NOTATNIKIEM PLIK FSW_PSW.MAN OPRÓŻNIAMY JEŚLI NIE JEST PUSTY
ZAMYKAJĄC ZAPISUJEMY ZMIANY WTEDY PUNKT 16 I GOTOWE
5 - BACK
6 - F4 PROCES ECU
8 - OK
BEZ OBAW I MIŁEJ ZABAWY :cool2:
PZDR
Ostatnio edytowano 01 Sie 2016 20:39 przez bmw-power, łącznie edytowano 50 razy
bmw-power
Dołączenie: 06 Maj 2012 16:56
Miejscowość: Szczucin
Moje BMW: E65 730d 2002 + E65 735i 2002
Re: INSTRUKCJA KODOWANIA Z NCS DUMMY
Postprzez Din76 » 01 Gru 2014 16:51
Bardzo dobra instrukcja kolego :cool2:
Możesz jeszcze zrobić jak będziesz miał czas przez Read ECU (F4) zamiast F5 BASIC FUNCTIONS / capiReadSgGetFswPsw / OK
Mam ncs dummy, ele jakoś łatwiej przez Coding Tool, może kwestia przyzwyczajenia.
Din76
Dołączenie: 21 Lis 2011 00:33
Miejscowość: Lublin\Kraśnik
Moje BMW: Bmw e46 320d, BMW E91 N47
Postprzez bmw-power » 01 Gru 2014 17:11
Ok, masz racje :cool2:
Gdzie pobrać coding tool?
Żeby wszystko działało ok, trzeba jeszcze poprawnie skonfigurować profil EXPERTMODUS
HASŁO: REPXET
Ostatnio edytowano 13 Sty 2015 18:10 przez bmw-power, łącznie edytowano 5 razy
bmw-power
Postprzez Din76 » 01 Gru 2014 17:28
http://chomikuj.pl/Dinpl/BMW/NCS+4.0.1/ ... ar(archive)
W windows 7 , 8 32/64bit przed uruchomieniem z dowolnej lokalizacji wejdź we Właściwości, zakładka, zgodność (ustaw na Windows XP SP3 i zaznacz uruchom jako administrator) Aplikacja Coding Tool
(nawet myślałem aby sobie tłumacza przetłumaczyć na język Polski)
Din76
Postprzez Tombo* » 01 Gru 2014 18:26
Na polski byloby ciekawe Din
Tombo*
Dołączenie: 13 Lis 2014 02:49
Miejscowość: GB
Moje BMW: E90 2006
Postprzez Din76 » 01 Gru 2014 18:40
Nie jest trudno otwierasz plik w Coding tool\ "Translations" i tłumaczysz zamiast angielskiego polskie tłumaczenie, muszę powiedzieć że najnowszy NSC dummy ma lepsze
tłumaczenie, tzn więcej jest przetłumaczone, sprawdziłem można przełożyć do Coding tool
Din76
Postprzez Bezio » 06 Gru 2014 06:48
Dziękuje bmw-power. Jesteś gość! Bardzo przydatna instrukcja.
Pozdrawiam.
Bezio
Dołączenie: 10 Kwi 2011 02:26
Miejscowość: Legnica
Moje BMW: E61 535d 2004r. M57N
Postprzez Din76 » 12 Gru 2014 17:49
Kolego bmw-power muszę Cie znowu pochwalić kodowałem dziś e46 KMB licznik i dla sprawdzenie i nauki zamiast coding tool wybrałem NCS DUMMY i muszę
przyznać, mimo żę jest bardziej skomplikowany, NCS DUMMY jest lepszy do kodowania wszystkie funkcje do zaznaczenia są widoczne nie trzeba zgadywać
nie mówię to o prostej funkcji jak aktiv i nicht_aktiv ale chciałem sobie kiedyś zmniejszyć przebieg miedzy wymianami oleju z 22-tyś do 16-tyś i nie pozwalał na to
sterownik KMB już wiem dlaczego jest tylko kilka możliwości do wyboru gdybym wybrał 15-tys od razu to bym zakodował ale w Coding tool nie ma tej funkcji widocznej
a w NCS DUMMY jest wszystkie możliwości pokazane tylko zaznaczamy właściwe i gotowe.
I też jest funkcja szukaj, jak koduje to mam przygotowaną ściągawkę w notatniku funkcje do
zakodowania i tylko kopiuje i wklejam do ramki szukaj lupa FIND po prawej stronie i samo odnajduje funkcje do zmiany w FSW_PSW po zmianie export man i
dla mnie F2 Codiren SG >F3 i gotowe
:cool2:
Din76
Postprzez bmw-power » 12 Gru 2014 20:28
NcsDummy jest najlepszy :cool2:
Próbowałem w tym tyg z bmw coding tool ale słabo w porównaniu do dummy
A i chyba wezmę się za tłumaczenie z ANG na PL
Jest ktoś chętny do pomocy? chodzi o prawidłowa interpretację tłumaczeń
bmw-power
Postprzez Din76 » 12 Gru 2014 21:24
Nawet mam gdzieś tłumaczenie , ale nie trzeba usuwać eng tylko można dopisać po polsku jak tak robię w INPIE w plikach ipo wtedy lepiej się uczysz angielskiego
jak znajdę to wkleję wszystkie co mam na forum
Din76
Postprzez bmw-power » 12 Gru 2014 21:31
Chciałem całkiem ang zastąpić polskim i byłoby ok, tak to za dużo tego może być.
Wrzuć co masz
bmw-power
Postprzez Din76 » 13 Gru 2014 15:29
Kod: Zaznacz wszystko
NCS SPIS OPCJI PLIK FSW
HEIMLEUCHTEN - czas świecenia
(wert_02 - minuta LUB wert_03 - 2 minuty)
HEIMLEUCHTEN_ABBRUCH : - wyłaczenie odprowadzania
HEIMLEUCHTEN_AL : - odprowadanie światłami mijania
HEIMLEUCHTEN_BL : - odprowadzanie STOPami
HEIMLEUCHTEN_BLK : - odprowadzanie kierunkowskazami.
HEIMLEUCHTEN_FL : - odprowadzanie drogowymi
HEIMLEUCHTEN_FUNKSCHL : - odprowadzanie po zamknięciu pilotem
HEIMLEUCHTEN_KL58G : - odprowadzanie światłami wewnętrznymi (+popielniczka, słupki itp.)
HEIMLEUCHTEN_KZL : - odprowadzanie oświetleniem tablic rej.
HEIMLEUCHTEN_NSL : - odprowadzanie tylnymi przeciwmgielymi
HEIMLEUCHTEN_NSW : - odprowadzanie halogenami
HEIMLEUCHTEN_RFS : - odprowadzanie światłami cofania
HEIMLEUCHTEN_SL_H : - odprowadzanie tylnymi postojówkami
HEIMLEUCHTEN_SL_V : - odprowadzanie przednimi postojówkami
_
Tu masz komendy. miłego szukania
**** FSW-PSW :action caused by aktiv/nicht aktiv selection ****
ABFRAGEZEIT_AHM : - czestotliwość kontroli modułu przyczepy
ABKLAPPSTELLUNG : – zmiana położenia wycieraczek – po zgaszeniu auta poz. pionowa gdy “active”
ABKLAPPWERT : – wartość klapy Touring
ABSCHALTDREHZAHL_ANLASSER : – odcięcie rozrusznika przy RPM
ABSCHALT_GESCHWINDIGKEIT : - prędkość wyłączania
ABSCHALT_KL50 : - wyłącza przycisk rozrusznika gdy “active”
ABSCHALTKRITERIUM : – włącza zabezpieczenie (odbojnik szyby) kiedy „active“
ABSCHALTMELDUNG : – potwierdzenie wyłączenia
ABSCHALTSPANNUNG_KL_30 : – wartość wyłączenia
ABSCHALTUNG_UNTERSPG : – przekroczona wartość wyłączenia (w dół)
ABSCHALTUNG_VERBRAUCHER : – wyłączenie - użytkownik
ABSCHALTWEG : – wyłączanie po przebiegu
ABSENKUNG_10_KM/H : - Obniżanie po 10 km/h
ABS_MIN_STELLUNG_2 : – minimalne położenie ABS
ABSTAND_HOLD_NORMAL_MODE : – tryb normalny utrzymywania dystansu
ABSTAND_KALTPULSE :
ABSTELLPOS_CUSTOM : shut down?
ABSTELLPOS_SMC :
ABTASTRATE_DYN  ynamic feeler rate. wert_01
ABTASTRATE_TREND :
ACC_FLAG : – aktywacja wskaźnika tempomatu
ADRESSE_AUSWERTEN : – ewaluacja (kontrola) adresu
AIRBAG_BEIFAHRER_1 : – poduszka pasażera
AIRBAG_FAHRER_1 : – poduszka kierowcy
AIRBAG_TRIGGERED_E-CALL : – wystrzelona poduszka dzwoni pod 112 telefonem pokładowym
AKUSTIK_ABBLENDLICHT : – alarm słabej wiązki (drogowe)
AKUSTIK_BREMSLICHT : – sygnał dźwiękowy światła stopu
AKUSTIK_DSC_ASC : – alarm aktywnego DSC lub ASC
AKUSTIK_GURT_WARN : – alarm niezapiętego pasa bezp.
AKUSTIK_HECKKLAPPE : – alarm otwartego bagażnika
AKUSTIK_KONZEPT : alarm concept ?
AKUSTIK_PARKBREMSE : – alarm hamulca postojowego (ręczny)
AKUSTIK_RDKS : – alarm niskiego ciśnienia powietrza
AKUSTIK_RUECKLICHT : – alarm – światła tylne
AKUSTIK_TUEREN : – alarm otwartych drzwi
AKUSTIK_WASCHWASSER : – alarm niski poziom płynu do spr.
AL_ALS_DRL : – słabe światła podczas użytkowania świateł dziennych
ALARM_AKUSTISCH : – wybór dźwięku alarmu
ALARM_AKUSTISCH_LANG : - długi dźwięk alarmu
ALARMSCHALTER_SI_FZG : – przełączanie alarmu
ALARMSCHALTER_TAXI : przełącznik alarmu (wersja taxi)
ALARM_OPT_ABBLENDLICHT : miganie słabymi światłami kiedy alarm aktywowany
ALARM_OPT_WARNBLINKER : miganie awaryjnymi kiedy alarm aktywowany
ALARM_OPT_FERNLICHT : miganie mocnymi światłami kiedy alarm aktywowany
ALC : – automatyczna kontrola poziomu
ALC_ABSENKUNG_10_KM/H : Automatyczna kontrola obniżania o 10km/h
ALC_AUSWERT_GRADIENT :
ALC_AUSWERT_PROP_ABWEICH :
ALC_FAILSAFE_FCT_EIN :
ALC_FAILSAFE_NSW_AUS_OPT1 :
ALC_FAILSAFE_NSW_AUS_OPT2 :
ALC_FAILSAFE_NSW_EIN :
ALC_FAILSAVE_NSW_LOCK :
ALC_FAILSAVE_NSW_NEU :
ALC_GRADIENT_SCHLECHTWEG :
ALC_KLS_ENABLE :
ALC_KLS_DISABLE :
ALC_LED_DEF : Automatyczna kontrola uszkodzonych LED
ALC_LWR_VORZEICHEN :
ALC_SAETT_TIMER_SCHLECHTW :
ALC_SCHWENK_LATCH :
ALC_VERBAUT
AL_KL_50 : słabe światła kiedy zapłon ON
ANHAENGERKUPPLUNG : wyłączanie tylnego PDC kiedy podłączona wiązka przyczepy
ANHAENGERMODUL_PWM_WERT : Wartość napięcia modułu przyczepy.
ANHEBUNG_175_KM/H : podnoszenie przy 175 km/h??
ANKUNFTSZEIT_VON_NAVI : czas przybycia pobierany z NAVI
ANLAUFSTROMBEGRENZ_MEMO : - ostrzeżenie zakłócenia napięcia
ANPRESSDRUCKVERSTELLUNG : - ustawienie sły nacisku wycieraczek
ANTI_DROEHN_STELLUNG :
ANZAHL_QUICK_RUNDEN : - ilośc szybkich obrotów.
ANZAHL_RAEDER_VERBAUT : - ilość zamontowanych kół
ANZAHL_SPRITZIMPULSE : - Ilość impulsów sprayowania
ANZAHL_STUFEN : - Ilość poziomów.
ANZEIGE_EML : - wyświetlanie ładowanie silnika el.
ANZEIGE_ANKUNFTSZEIT : - pokaż czas przybycia
ANZEIGE_HOCHLADEN : - pokaż przeładowanie.
ANZEIGE_OELSTAND_PREDRIVE : - pokaż poziom oleju przed ruszeniem
ANZEIGE_POSITION_AUS : - pokaż położenie.
ANZEIGE_SITZLEHNE_VER : - pokaż położenie fotela
ANZEIGE_UHR_IM_DISPLAY : - pokaż zegar
ASC : - kontrola trakcji
ASC3_AUSWERTUNG : – wykorzystanie ASC
ASC_PREDRIVE_UEBER_SG :
ASL :
ASL_DSC_5_7 :
ATEMP_WARNUNG_KALTLAND : – ostrzeżenie niskiej temp. zew
AUFHEIZAUTOMATIK : – automatyka ogrzewania
AUSSENGEFUEHRTE_SHDUSSENTEMP_ABH_GEBL_ANH_1 :
AUSSENTEMPERATUR_KORR : - korekta wskazań temp zewnętrznej
AUSSENTEMP_BEWERT : - szacowanie temp zewnętrznej
AUSSENTEMP_SENSOR : – czujnik temperatury zewnętrznej
AUSSENTEMP_SPERRZEIT_2 : – zablokowanie zegara (temp. zew.) – wartość nr 1
AUSSENTEMP_SPERRZEIT_3 : – zablokowanie zegara (temp. zew.) – wartość nr 2
AUSSENTEMP_WARN_AKUSTIK : – ostrzeżenie dźw. temp. zew.
AUSSENTEMP_WARNUNG_GONG : – gong ostrzegawczy temp.zew
AUSSTATTUNG_RPA : - wersja RPA
AUSSTELLFENSTER : – okno uchylne
AUSTAUSCHPUNKT : – punkt kontrolny (wymiana)
AUSWERT_GRADIENT : - Pochylenie przyczepy
AUSWERT_PROP_ABWEICHUNG :
AUT_SPIEGELVERSTELLUNG : – ustawienie lusterek dla kluczyka
AUT_SITZVERSTELLUNG : – automatyczne pozycjonowanie fotela kiedy drzwi otwarte, lub odrygl. pilotem
AUTO_B_ZUEND_EIN_1; – predkość nawiewu przy zapłonie ON dla klucz 1
AUTO_LED_GEBL_MANUELL :
AUTO_LED/SCHRIFTZUG : - ciągłość listwy LED
AUTO_LWR_ENABLE : – kontrola samopoziomowania świateł
AUTOMATISCHER_NOTRUF : – automatyczne powiadomienie na 112
AUTOM_FAHRL_STEUERG : – automatyczny kontroler przednich świateł
AUTO_ZV_DISABLE : – wyłączenie zamka.centr
BACKUP_ANTENNA : - zapasowa antena
BACKUP_BATTERY : - zapasowa bateria
BACKUP_BATTERY_ENABLED : - włączenie zapasowej baterii
BAUREIHE_A : – seria (np 3er/5er/7er)
BC_ANFORD_WEGFAHRSICH : - żadanie zezwolenia przez OBC
BC_CODE_AKTIV : funkcja blokady zapłonu przez OBC (CODE)
BC_DIGITAL_V = wyświetla cyfrowo prędkość na desce kiedy “active”
BC_KL_R : w pozycji R OBC pokazuje ostatnią wybieraną funkcję.
BC_V_KORREKTUR : - jeżeli “active” pozwala korygować wskazania prędkości INPĄ
BEDIENSTELLE_BFT : -Sekcja kontrolna drzwi kierowcy
BEGRENZUNGSLICHT_IN_PARK ; oświetlenie obrysowe podczas parkowania
BEIFAHRERBAG_STUFE2_1 : - poduszka pasażera w trybie “2_1”
BEIKLAPPEN_B_KOMFORTSCHL : przytrz. zamykanie na pilocie żeby zamknąć szyby I złożyć lusterka
BELUEFTUNGSKLAPPE_OEFF_1 : nawiewy otwarte podczas nagrzewania
BETRMODI_DEAKT_KL15_EIN :
BETR_STD_AUTO_LOESCH :B_SATELLIT_1
BETR_STD_NICHT_LOESCHEN : No deleting of usage hours
BEWERTUNG_FEHLER : - szacowanie uszkodzenia
BEWERTUNG_FEHLER_30 : - „hot-line“ szacowania uszkodzenia.
BEWERTUNG_FEHLER_31 : szacowanie uszkodzenia uziemienia podwozia
BFD_ABS_STUFE3 :
BFD_ASC_REG :
BFD_AX_REF :
BFD_ON :brake force display on
BFD_OPTION :
BFD_SCHWELLE :
BFD_ST3_ON :
BFD_SW1_STUFE :
BFD3_ASC_AKTIV :
BF_UEBERWACHUNG : - kontrola (obecności?) pasażera
BI_XENON : - bixenony.
BIXENON_EIN_BEI_LICHTHUPE : - błyśnięcie bixenon+halogeny
BL_ALS_SL_DIMMEN : - Stopy ściemniane do poziomu postojowych?
BL_DIMMEN : - zmienna siła światła STOP?
BL_DIMMUNGS_OPT_1 :
BL_ERSETZ_DEFEKT_SL : - światła STOP zastępują spalone pozycyjne.
BL_ERSETZT_DEFEKT_BLK : - światła STOP zastępują spalone kierunkowskazy
BLEND_CHECK_IST_WINKEL :
BLEND_CHECK_SOLL_WINKEL :
BL_GEDIMMT_ALS_ERSATZ :brake light &
BL_GED_ALS_ERSATZ_MIT_AH :brake light &
BLINKIMPULS_CRASHBLK : - częstotliwość pracy kierukowsk.[01&02norm.03b.sz.04podw.prędk]
BLINKIMPULS_WARNBLK : - częstotliwość pracy awaryjnych.[01&02norm.03b.sz.04podw.prędk]
BLK_DIMMEN : - przyciemnione kierunkowskazy.
BLK_DIMMUNGS_OPT_1 : - dostosowanie przyciemniania kierukowskazu
BLK_H_L_PICT : - sygnał tylnego lewego kierunkowskazu na desce rozdziel.
BLK-H-R-PICT : - sygnał tylnego prawego kierunkowskazu na desce rozdziel.
BLK_V_GED_ALS_PARKLICHT : - przednie kirunki jako światła parkowania
BLK_V_GED_ALS_SIDEMARK : - tylne światła wł., halogeny wł, jako obrysy
BLK_V_GEDIMMT_ALS_ERSATZ : - front turn light & together as
BLK_V_L_PICT : - sygnał przedniego lewego kierunkowskazu na desce rozdziel.
BLK_V_R_PICT : - sygnał przedniego prawego kierunkowskazu na desce rozdziel.
BLS_PRUEFEN : - kontrola przycisku światła stopu
BLST1_BLST3 :
BL_UND_BLK_H_GEM_BLK : - STOP I tylne kierunki świecą razem podczas hamowania
BL_UND_BLK_H_GEMEINSAM : - STOP I tylne kierunki świecą razem
BL_UND_BLK_H_GEM_WBL : - STOP I tylne kierunki świecą razem podczas zagrożenia
BORDMONITOR : - monitor pokładowy
BORDNETZ : - zsieciowanie pokładowe (navi)
BPLUS_TRENNUNG1_1 : - rozdział baterii zapasowej
BRAKE_FORCE : - siła hamowania
BREMSFLUESSIGK_INV : brake fluid ?
BREMSLICHT_ALS_STANDLICHT : Brake Lights as parking lights
BREMSLICHTSCHALTER : wyłącznik świateł STOP
BREMSWARNLEUCHTE : Ostrzegawsze światło hamowania
B_SATELLIT_1 :
CAN_11H :
CAN_AUSFALL_BEWERTUNG : ocena awarii CAN
CAN_EBV : - rozdział siły hamowania na CAN
CAN_INSTR2_SENDEN :
CAN_OELDRUCK : - ciśnienie oleju dla linii CAN
CAN_OELDRUCKSCHALTER : - przełącznik ciśnienie oleju dla linii CAN
CAN_S_GSU : - czujnik zmierzchu na linii CAN
CC_ABBLENDLICHT : check control słabe światła (mijania)
CC_AUSSENTEMPERATUR : check control niska temperatura zewnętrzna
CC_BREMSLICHT: Check control światła STOP
CC_BREMSLICHT_MITTE :Check control środkowe światło STOP
CC_BLINKER_HINTEN ;Check control tylne kierunkowskazy.
CC_BLINKER_VORN :Check control przednie kierunkowskazy
CC_FERNLICHT :Check control mocne światła (drogowe)
CC_HECKKLAPPE :Check control tylna klapa
CC_KENNZEICHENLEUCHTE_LI:Check control number oświetlenie tablicy rejestracyjnej
CC_LAMPEN :Check control światła
CC_MELDUNG_AL_L :Check control informacja świateł mijania
CC_NSL_LINKS :Check control tylne lewe przeciwmgielne
CC_RUECKLICHT :Check control światła cofania
CC_RUECKLICHT_2_RECHTS ;Check control prawe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_3_LINKS :Check control lewe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_3_RECHTS :Check control prawe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_LINKS :Check control lewe światło cofania aktiv / nicht_aktiv
CC_RUECKLICHT_RECHTS :Check control prawe światło cofania.
CC_STANDLICHT_LINKS :Check control lewe światło parkingowe aktiv / nicht_aktiv
CC_STANDLICHT_RECHTS :Check control prawe światło parkowania.
CC_TUEREN :Check control drzwi
CC_WASCHWASSER :Check control płyn spryskiwacza szyb
CC_ZUSATZBLINKER :Check control zewnętrzna sygnalizacja skrętu.
CENT_LOCK_MGL_VO_TUER_AUF :
CHECK_FGN_SMC_ALC_OFF :
CHECK_IGNITIONA :
CHECK_IGNITIONC :
CHECK_IGNITIONK :
CHECK_SMC_ERROR :
CLT_AKTIV_IM_CRASH_MODE :
CODIERUNG_ERFOLGT : - wykonanie kodowania. (CODE)
CODIERWERT : - wartość kodowania (CODE)
COD_IFL :
COD_IFL_AN_PIN48 :
COD_IFL_ASYNC :
CORNERING_BREAK_CONTROL : - Kontrola dohamowania w zakręcie
CRASH_DISABLE_BEWERTUNG_10S :
CRASH_DISABLE_HECKKL_10S :
CRASH_KLEMME_58G_EIN : - włączenie oświetlenia wewnętrznego podczas wypadku.
CRASH_WARNBLINKEN : - Włącz awaryjne podczas wypadku
CUSTOMER_CALLS_OVER_GMIN
CYCL_TI_BLK;1 – dotknięty kierunek miga raz, dwa lub 3 razy.
DATENSATZ_1
DAUER_DYN_NACHFUEHRUNG :
DAUERFAHRLICHT_EU : - Czujnik świateł - Europa.
DAUERFAHRLICHT_US : - Czujnik świateł - US.
DBC_DBS : - controla dynamicznego hamowania, dynamiczne hamowanie.
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_LWR_SENSOR_HI : - uszkodzony tylny czujnik poziomowania lamp przednich.
DEF_PIN_20_DEFEKTBLINKEN :
DEF_PIN_20_VOR :
DEF_PIN_37_DEFEKTBLINKEN :
DEF_PIN_37_VOR :
DELTA_LIMIT_GESETZ : - wartość limitu zmiennej
DIAGNOSE_DELAY_ZEIT : - diagnoza czasu opóźnienia
DIAGNOSE_SCHRITTMOTOR : - diagnoza silnika krokowego
DIAGNOSE_ZWP :
DIFFERENZ_ANLAUF_BLOCK :
DISPLAYANZEIGE_HIGH : - temperature wyświetlana na IHKA jako HI jeżeli jest 91°F jeżeli “in-active”
DISPLAYANZEIGE_LOW : - temperature wyświetlana na IHKA jako LO jeżeli jest 59°F jeżeli “in-active”
DISPLAY_GEBLAESRAHMEN :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DREHZAHL_KENNLINIE : krzywa charakterystyki RPM
DRIFT_DEKR : - zmniejszeje uślizgu (drift)
DRIFT_INKR : - zwiększenie uślizgu (drift)
DRIFT_SCHWELLE : - limit uślizgu
DRL_BLK_VORN_GEDIMMT : przyciemnione kierunkowskazy jako światła dzienne.
DRL_DIMMUNG : - przyciemnienie DRL
DROSSEL : - przpustnica
DRUCK_OFFSET : - Wyrównanie ciśnienia.
DRUCKMODELL_HINTERACHSE : - model ciśnienia tylnej osi.
DRUCKMODELL_VORDERACHSE : - model ciśnienia przedniej osi.
DRUCKMODELLPARAMETER : - parametr modelu ciśnienia.
DRUCKPUMPE_DREHRICHTUNG : - wytyczne ciśnienia dla pompy.
DSC_DEF_GONG : sygnał ostrzegawczy kiedy DSC aktywowane.
DSP_ACOUSTIC_PROFILE : - Cyfrowy Dźwięk Przetwarzania profilu.
DSP_CDC_DIGITALLTG : - processor cyfrowego dźwięku
DTC_LAMPE :
DWAH_PIN_C17 : - sygnał syreny alarmu
DWA_BLK_ABSCHALTEN : zamknięcie szyb podczas aktywowania alarmu
DWA : - system zabezpieczenia przed kradzieżą
DWA_HANDSCHUHFACHKONTAKT : - przełącznik alarmu - schowek na rękawiczki.
DWA_HECKKLAPPENKONTAKT : - przełącznik alarmu - bagażnik.
DWA_HECKSCHEIBENKONTAKT : - przełącznik alarmu – tylna szyba
DWA_NOTENTSCHAERFEN : - alarm nie będzie deaktywowany
DWA-QUITTIERUNG : - kwitowanie systemu antywłamaniowego
DYNAM_LWR_ENABLE : - aktywne położenie pionowe przednich lamp
DYN_BREMS_UNTERSTUETZUNG : - aktywna asysta hamowania
E52_FUNKTIONEN : - Funkcje BMW Z8
E83_FUNKTIONEN : - Funkcje BMW X3
E85_FUNKTIONEN : - Funkcje BMW Z4
E52_LINKS_LENKER : - Funkcje BMW Z8 dla ruchu prawostronnego
E52_RECHTS_LENKER : - Funkcje BMW Z8 dla ruchu lewostronnego
E53_FAHRZEUG :
E9X_HIMMEL :
EBV_LAMPE : - elektroniczna siła światła STOP
E_CALL_COUNTD_DEL_TMR : - czas opóźnienia odliczania połączeń alarmowych
E-CALL_HARDKEY_FITTED : - zainstalowany przycisk połączenia alarmowego
ECHOSCHWELLWERTE_ECKE_HI : - PDC sensor tylny narożnik
ECHOSCHWELLWERTE_ECKE_VO : - PDC sensor przedni narożnik
ECHOSCHWELLWERTE_MITTE_HI : - PDC sensor środek tył.
ECHOSCHWELLWERTE_MITTE_VO : - PDC sensor środek przód.
EC_LUEFTER : - wentylator
EEPROM_SHD :
EHC : - elektroniczna kontrola wysokości
EINGANG_2 : - wejście (danych) 2.
EINGANG_2_KONTAKT_GESCHL : - zamknięty kontakt 2 wejścia (danych).
EINKLEMMSCH_HINTEN : - sensor zabezpieczający przyciśnięcie – tylna szyba
EINKLEMMSCH_REVERSIEREN : - dystans powrotu sensora antyprzyciśnięcia
EINKLEMMSCH_VORNE : - sensor zabezpieczający przyciśnięcie – przednia szyba
EINSCHALTMELDUNG_BEI_1MA : start?
EINSCHALTMELDUNG_IMMER : - zgłoszenie błędu - zawsze.
EINSCHALTVERZOEGERUNG : - włączanie stopniowe.
EINSPRITZANLAGE_CAN : - informacje z wtrysku paliwa do linii CAN
EINSTIEGSHILFE : - wspomaganie kierownicy kiedy klucz w pozycji w pozycji “1”
EINSTIEGSHILFE_HOEHE : - automatyczna regulacji wysokości kierownicy
EINSTIEGSHILFE_LAENGE : - automatyczna regulacja wysunięcia kierownicy
EIS_AUSBLENDEN : - stopniowe wyłącznaie rozmrażacza
EL_DURCHLAUFERHITZER : - elektryczne podgrzewanie.
E_LUEFTER :
ENABLE_EURO_NCAP : - włącz NCAP
ENABLE_US_SBR : - włącz SBR
ENTFALL_ZV_BEDIENST_HECK :
ENTFROSTKLAPPE_SCHLIES_1 : - rozmrażacz 1 zamknięty
ENTFROSTKLAPPE_SCHLIES_2 : - rozmrażacz 2 zamknięty
ENTFROSTKLAPPE_SCHLIES_3 : - rozmrażacz 3 zamknięty
ENTFROSTKLAPPE_SCHLIES_4 : - rozmrażacz 4 zamknięty
ENTSICHERN_CENTERLOCK : - przycisk centralnego w kabinie działa bez kluczyka
ENTPRELLZAHL_FEHLERERK : - roznawanie numeru otwieranego błedu.
ENTRIEGELN_HKL : - otwórz bagażnik
ENTR_HKL_MGL_WENN_VER :
ENTR_HS_MGL_WENN_VER :
ENTR_KL.R_30S_NACH_SICH :
ENTSICHERN_CENTERLOCK : - kabinowy przycisk centralnego działa kiedy drzwi zamknięte I kluczyk nie w pozycji „zapłon“ kiedy „active”
EPSILON_DELTA_A :
ERKENNUNG_BREMSLICHT : - rozpoznawaj światła STOP
ERKENNUNG_SITZBELEGUNG_1 : - rozpoznawanie położenia fotela (nie wyłaczaj ponieważ system AIRBAG zwariuje)
ER_KEYOUT_AUTOVR : - otwórz centralny po zatrzymaniu auta (w module CAS)
ERR_LWR_L_IGNORIEREN :
ERR_LWR_R_IGNORIEREN :
ERR_SCHWENK_L_IGNORIEREN : - ignorowanie błedu lewego łożyska
ERR_SCHWENK_R_IGNORIEREN : - ignorowanie błedu prawego łożyska
EWS_3_SCHNITTSTELLE : electronic immobiliser interface
FAHRZEUG_HERSTELLER : - producen pojazdu
FAHRZEUG_TYP : - Typ pojazdu
FE_SCHEIBENWISCHER : - błąd wycieraczki szyby
FEHLER_ABBLENDLICHT : - błąd świateł mijania.
FEHLER_ABTAKTEN : - błąd taktowania
FEHLER_ANHAENGER : - błąd przyczepy.
FEHLER_BL_BLINKEN : - raportuj bład świateł STOP.
FEHLER_BREMSLICHT : - bład świateł STOP
FEHLER_NSL_RECHTS : - raportowanie błędu tylnego przeciwmgielnego melden/nicht melden (raportuj/nie)
FEHLER_SCHALTER_BREMSL : - raportuj zaburzenia pracy przełacznika hamulca.
FEHLER_1_CODE : - kod błedu „1“
FEHLER_1_HAEUFIGKEIT : - błąd „1“ częstotliwości
FEHLER_5_HAEUFIGKEIT : - bład „5“ częstotliwości
FEHLER_HECKSCHEIBE : - bład tylnej szyby
FEHLERZAEHLER : - licznik błedów
FERNBEDIENUNG : - kontrola zdalnego serwisu
FERNLICHT_DRL : - DRL świateł drogowych.
FERNWIRKEN_GENERELL : - zdalna kontrola ogólnie
FERNWIRKEN_NAVZIELE : - zdalna kontrola założeń NAVI
FERNWIRKEN_POSITION : - zdalna kontrola pozycji
FERNWIRKEN_STANDHEIZUNG : - zdalna kontrola ogrzewania
FERNWIRKEN_TELEFONLISTEN : - zdalna kontrola książki telefonicznej
FENSTERHEBER_HINTEN : - domykanie tylnych szyb
FENSTERHEBER_VORNE : - domykali przednich szyb
FH_ABSCHALTKRITERIUM : - US oznacza wyłączenie domykania szyb po zgaszeniu auta (z paneli na drzwiach. ECE oznacza aktywne domykanie po zgaszeniu przez 1 minutę
FH_ABSENKUNG_SPERREN : - wyłącz zasilanie samoczynne do opuszczania szyb.
FH_ABSENKEN_VERDECK_OEFF : - opuść szyby kiedy otwierasz dach.
FH_ABSENKUNG_SPERREN : - wyłącz samoczynne opuszczanie szyb
FH_AUF_STUFE2_KLR_AUS :
FH_BEIFAHRERTUER_TIPP_AUF : - szyba pasażera opuszczana jednym kliknięciem
FH_BEIFAHRERTUER_TIPP_ZU : - szyba pasażera podnoszona jednym kliknięciem
FH_FAHRERTUER_TIPP_AUF : - szyba kierowcy opuszczana jednym kliknięciem
FH_FAHRERTUER_TIPP_ZU : - szyba kierowcy podnoszona jednym kliknięciem
FH_INIT_TRANSPORTMODE : - szyby samoczynne w trybie transportowym
FH_NACH_TUERE_AUF : - domykanie szyb kiedy drzwi otwarte
FH_TIMEOUT : - maksymalny czas pracy silnika szyb
FH_TIPP_DISABLE_TUER_AUF :
FH_TUEREN_HINTEN_TIPP_AUF : - tylne szyby opuszczane jednym kliknięciem
FH_TUEREN_HINTEN_TIPP_ZU : - tylne szyby podnoszone jednym kliknięciem
FH_ZTR_SCHALTER_TIPP_AUF : - 4 szyby opuszczane jednym kliknięciem.
FH_ZTR_SCHALTER_TIPP_ZU : - 4 szyby zamykane jednym kliknięciem.
FILTER_DETEKTION_WEIT :
FL_AL_AUS : - światła drogowe jako mijania
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
FLC_SCHWELLWERT_SATZ – utomatyczna kontrola świateł drogowych (zmienne/normalne)
FL_DIMMUNG_ALS_DRL :wert_01 = 0 % wert_02 = 18,82 % wert_03 = 20,39 % wert_04 = 43,92 %wert_05 = 18,82 % ustawienia intensywności świateł drogowych działających w trybie dziennym
FL_KL_50 : - św. drogowe właczane przy zapłonie.
FL_UND_NSW_NICHT_GLEICHZ : - światła drogowe I przeciwmgielne nie świecą razem
FONDGEBLAESE : - wentylator nawiewu tylnej kanapy
FOND_MODUL_1 : - moduł tylnego nawiewu
FS_UNLOCK_300MS_P_BUS : - odblokowanie czujnikiem zderzenia
FUHRPARK_FLOTTENMODUS : - Drive park fleet mode.
FUNK_INNENRAUMSCHUTZ : - monitoring wnętrza pojazdu
FUNKINNENRAUMSCHUTZ_HI : - monitoring wnętrza pojazdu - tył.
FUNKTION_CABRIO : - funkcja cabrio
FUNKTION_DSC : - funkcje DSC
FUNKTION_DTC : - funkcje DTC
FUNKTION_RPA : - funkcje RPA
FUNKTIONEN_TOURING : - funkcje touringa.
FUNKTIONTUERSCHLOSS : - funkcje centralnego
FUNKUHR : godzina zegarka
FUSSRAUMKLAPPE SCHLIES : - nawiewy stop zamknięte
FZG_RADSTAND : - stan kół pojazdu.
FZG_VERZOEGERUNG : - zwalnianie pojazdu.
GEARMOMENTREGLER_MAX_HA : - kontrola maksymalnego momentu obrotowego tylnej osi.
GEARMOMENTREGLER_MIN_HA : - kontrola minimalnego momentu obrotowego tylnej osi.
GEBL_OFF_MODE :
GEBLAESE_BALKEN : - automatyczny tryb linii dmuchawy
GEBL AUT B ZUEND EIN : - nawiew przy zapłonie
GEBLAESEKORREKTUR : - korekta nawiewu – słabiej/mocniej/nicht activ
GEBLAESEBALKEN_AUT_MOD_1 : linia dmuchawy w automatycznym trybie “1”
GED_FL_ALS_DRL : - przyciemnione światła drogowe jako światła jazdy dziennej (USA style)
GEDIMMT_BL__BEGRENZ_LICHT : - przyciemnione STOPY jako obrysówki.
GEDIMMT_BLK_BEGRENZ_LICHT : - przyciemnione kierunki jako obrysówki.
GENERATOR_UEBER_CAN : - pradnica przez linię CAN
GERAETENAME : - nazwa urzadzenia.
GEREGELTER_KOMPRESSOR : - sprężarka wyregulowana
GESCHW_PRUEFUNG : - sprawdzenie prędkości.
GESCHW_VERDECK_AKTIV : - kontrola prędkości dla cabrio.
GESCHWINDIGKEIT : - prędkość.
GESCHWINDIGKEIT_FEHLER : - bład prędkości.
GETRIEBE : - skrzynia biegów.
GETRIEBE_ANZEIGE_GANG : - wyświetlanie bieżącego biegu.
GETRIEBEART : - typ skrzyni biegów.
GLASDACH : - szyberdach
GPS_UHR : - pobierz z GPS czas dla zegara radia – w DE i UK niezbędny odbiornik LW.
GRADIENT_MM_ZUGABE : - stopniowanie regulacji w milimetrach
GRADIENT_SCHLECHTWEG – wysokość przy złej nawierzchni
GURTKONTAKT_MELDUNG_UEBER : - ostrzeżenie o pasach przez linię K
GURTSCHLOSS_BEIFAHRER_1 : - pasy pasażera.
GURTSCHLOSS_FAHRER_1 : - pasy kierowcy
GURTSCHLOSS_HINTEN_LI_1 : - pasy lewy tył 1
GURTSCHLOSS_HINTEN_LI_2 : - pasy lewy tył 2
GURTSCHLOSS_HINTEN_RE_1 : - pasy prawy tył 1
GURTSCHLOSS_HINTEN_RE_2 : - pasy prawy tył 2
GURTSCHLOSS_HI_MITTE_1 : - pasy tył środek.
GURTSCHLOSS_SPANNUNGSS_1 : - napięcie/naprężenie pasów.
GURTSCHLOSS_STROMSS_1 : - zasilanie pasów.
GURTSTRAFFER_BEIFAHRER_1 : - naprężenie pasów - pasażer
GURTSTRAFFER_FAHRER_1 : - naprężenie pasów kierowca
GURTSTRAFFER_HINTEN_LI_1: - naprężenie pasów – lewy tył 1
GURTSTRAFFER_HINTEN_LI_2: - naprężenie pasów – lewy tył 2
GURTSTRAFFER_HINTEN_MI_1: - naprężenie pasów – środek tył 1
GURTSTRAFFER_HINTEN_MI_2: - naprężenie pasów – środek tył 2
GURTSTRAFFER_HINTEN_RE_1: - naprężenie pasów – prawy tył 1
GURTSTRAFFER_HINTEN_RE_2: - naprężenie pasów – prawy tył 2
GURTWARNUNG_EURO_NCAP : - ostrzeżenie o pasach wg NCAP
GURTWARNUNG : - ostrzeżenie o pasach
GURTWARNUNG_GONG : - Dźwięk ostrzegawczy pasów
GURTWARNUNG_TEXT : - text ostrzegawczy pasów
HALB/VOLLSCHRITT : - Step całkowity/połowa
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HALTEZEIT : - czas zatrzymania
HALTEZEIT_VENTILE : - czas odcięcia zaworów.
HANDY_TYP : - typ komórki.
HARDTOP_ERKENNUNG : - wykrywanie hardtop
HBA_DSC_5_7 :
HEBEN_AUS_GEOEFFNET : - unoszenie włączone
HECKKLAPPE : - klapa bagażnika.
HECKKLAPPE_ENTSICHERN : - otwieranie klapy pilotem
HECKKLAPPEN_LOGIK : - pozycja klapy bagażnika.
HECKSCHEIBE_ENTRI_INNEN : - podgrzewanie tylnej szyby
HECKSCHEIBE_HEIZZEIT : - czas ogrzewania tylnej szyby
HEIMLEUCHTEN : - wert_01 wyłącza, wert_02 włącza odprowadzanie do domu (błysnięciem drogowymi przy wyjętym kluczyku)
HEULTON : - wyjąca syrena
HHS_AUTOMATIK : - automatyczne odmglanie tylnej szyby
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HIMMEL_AUTO_AUF : - autoroleta otwarta
HIMMEL_AUTO_ZU : - autoroleta zamknięta
HKL_SPERREN_BEI_ZS : - zamknij klapę bagażnika zamkiem centralnym
HUB_VERZOEGERUNG_FH_VORN :
HWL_1 :
HYDRAUL_HECKKLAPPE : - hydrauliczne otwieranie bagażnika
HYDR_BREMSKRAFTVERTEILUNG : - hydrauliczne rozdzielanie siły hamowania.
HYD_HECKKLAPPE_OHNE_PDC : - hydrauliczna klapa bagażnika bez PDC
IB_AUS_NACH_X_SEKUNDEN : - oświetlenie wnętrza wył po x sekundach
IB_BEI_KL.R_AUS : - włączanie oświetlenia wnętrza przy wyłaczonym zapłonie po jeździe na światłach
IB_CRASH_ON_0_KMH : właczenia oświetlenia wnętrza przy 0 km/h
IB_EIN_16MIN_WENN_STANDLI : sygnał kontrolny oświetlenia wnętrza
IB_EIN_BEI_HKK/HSK :
IB_EIN_HK_AUF :
IB_EIN_SCHLOSS_ENTRIEGELN : - włączenie oświetlenia wnętrza przy otwarciu kluczykiem
IB_POWER_CONF_0 : - oświetlenie wnętrza konfiguracja zerowa
IBUS_R_GANG : - wsteczny na linii I.
IB_SPERRE_BEI_FEHLER : - zablokuj oświetlenie wnętrza przy błędzie
IK_BUS_TEILNEMER :
ITS_FRONTCRASH_1 : napełnij przednią osłonę
ITS_LINKS_1 : - napełnij przednią lewą osłonę
ITS_RECHTS_1 : - napełnij przednią prawą osłonę
INNENLICHT_AN_MEHRFACH_ZV : - dwukrotne wciśnięcie LOCK na pilocie zapala światła wewnątrz.
INTERM_FL : - przerywane światła drogowe.
INTERVALLZEIT_GESCHWABH : - zmienna czasu prędkości
IR_FERNBEDIENUNG : - zdalne sterowanie podczerwienią
IR_FERNBEDIENUNG_BF : - zdalne sterownaie podczerwienią dla pasażera
KALIBRIERFAKTOR_VERBRAUCH : - współczynnik kalibracji zużycia paliwa
KALTUEBERWACH_ZUSATZ_BLK : - zimny test zewnętrznych kierunkowskazów
KALTUEBERWACHUNG_AL : - zimny test żarówek świateł mijania
KALTUEBERWACHUNG_BL : - zimny test żarówek STOP
KALTUEBERWACHUNG_BLK_HI : - zimny test żarówek kierunkowskazów tył
KALTUEBERWACHUNG_BLK_VO : - zimny test żarówek kierunkowskazów przód
KALTUEBERWACHUNG_BL_MI : - zimny test żarówek STOP środkowy
KALTUEBERWACHUNG_FL : - zimny test żarówek świateł drogowych
KALTUEBERWACHUNG_KZL : - zimny test żarówek oświetlenia tablic
KALTUEBERWACHUNG_KZL_LI : - zimny test żarówek ośw tablic?
KALTUEBERWACHUNG_NSW : - zimny test żarówek halogenów
KALTUEBERWACHUNG_NSL : - zimny test żarówek przeciwmgielnego tył
KALTUEBERWACHUNG_RL : - zimny test żarówek świateł cofania
KALTUEBERWACHUNG_SL_LHI : - zimny test żarówek parkingowych (lewe)
KALTUEBERWACHUNG_SL_RHI : - zimny test żarówek parkingowych (prawe)
K_BUS_FB_SPERREN :
KBUS_FUNKTION : - funkcje linii K.
K_BUS_FREI_OHNE :
K_BUS_FS_UNLOCK_300MS :
KEINE_L_R_SYNCHRONISATION :
KEINE_PARKLICHT_FUNKT : - brak funkcji parkingowych
KENNFELDKUEHLUNG : - Test chłodzenia.
KENNLINIE_AUTO_GEBLAESE_1 : - automatyczny test nawiewu 1
KENNLINIE_AUTO_GEBLAESE_2 : - automatyczny test nawiewu 2
KENNLINIE_AUTO_GEBLAESE_3 : - automatyczny test nawiewu 3
KENNLINIE_AUTO_GEBLAESE_4: - automatyczny test nawiewu 4
KENNLINIE_GESCHWINDIGKEIT :- test prędkości liniowej.
KENNLINIE_LWR_SENSOR_HI : - autopoziomowanie świateł – linia tylnego czujnika.
KENNLINIE_LWR_SENSOR_VO : - autopoziomowanie świateł – linia przedniego czujnika.
KENNLINIENFELD2_AKTIV : linia testująca błędy „2“ aktywna
KENNLINIE_WAERMETAUSCHER : - szybka zmiana linii testującej (w trakcie pracy)
KEY_MEMORY : - pamięć kluczyka
KEY_MEMORY_IHK : - ustawienia temperatury ostatniego używania auta zapamiętana (dla kluczyka)
KEY_MEMORY_RADIO : - źródło/głośność I stacja radiowa zapamiętana z ostatniego użycia (dla kluczyka)
KINDER_SBE_1 : - siedzisko dla dziecka
KINDER_SBE_2 : - siedzisko dla dziecka
KISI_N_DEAKT_IM_CRASH :
KL50_ABSCHALT_AL : - kiedy kluczyk w pozycji start wyłącz światła mijania
KL50_ABSCHALT_FL : - kiedy kluczyk w pozycji start wyłącz światła drogowe
KL50_ABSCHALT_NSW : - kiedy kluczyk w pozycji start wyłącz halogeny
KL_50_CAN : - kluczyk w pozycji start – sygnał na linię CAN
KL_50_FUNK_AKT : - dwukrotne wciśnięcie LOCK na pilocie zapala światła wewnątrz.
KL58_HELLIGKEITSSTUFE – jasność oświetlenia wnętrza wert_01
KL58_HELLIGKEITSSTUFE_FLC – automatyczna kontrola jasności oświetlenia wnętrza.
KLAPPEN OEFFNEN : - otwarcie klap (nawiewu) przy zapłonie
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLASSIF_UEBERST_ENA :
KLEMME_15_LIEGT_AM_SG_AN : - przy zapłonie włącz zacisk 15
KLEMME_15_NOTWENDIG :
KLEMMENSTATUS :
KLEMME_50_UEBER_CAN : - zacisk 50 poprzez linię CAN
KL_ENABLE ; - AC
KLIMABETR BEI ZUEND EIN : Właczenie AC przy włączonym zapłonie (dla kluczyka)
KLIMATASTE_SPERREN :
KLS_BEI_AL_AKTIV
KM_SERVICE_INTERVALL : dystans międzyserwisowy
KOPFBAG_FOND_LINKS_1 : - ustawienia zagłówka lewego
KOPFBAG_FOND_RECHTS_1 : - ustawienia zagłówka prawego
KOMFOEFFNEN_SPERRE_KEY_IN : - komfortowe otwieranie cabrio poprzez przytrzymanie kluczyka w zamku w pozycji “otwórz”
KOMFORTFUNK_BEREICH_HEB : - funkcje komfortu w obszarze unoszenia
KOMFORTOEFFNEN_FB_O_FH_HI : - komfortowe otwieranie bez tylnych szyb
KOMFORTOEFFNEN_FB_O_SHD : - komfortowe otwieranie pilotem bez szyberdachu
KOMFOEFFNEN_SPERRE_KEY_IN – komfortowe otwieranie kluczykiem w zamku
KOMFORTOEFFNUNG : - komfortowe otwieranie – drzwi pilotem
KOMFORTOEFFNUNG_FB : - otwieranie dachu przez przytrzymanie “otwórz” pilotem, lub otwieranie wszystkich szyb&szyberdachu w nie-cabro
KOMFORTOEFFNUNG_BEREICH : - obszar komfortowego otwierania
KOMFORTOEFFNUNG_VERDECK : - komfortowe otwieranie dachu cabrio
KOMFORT_POS_AUF : - komfort – stan wł
KOMFORT_POS_ZU : - komfort – stan wył
KOMFORTSCHLIE_FB_O_FH_HI : - komfortowe zamykanie bez tylnych szyb
KOMFORTSCHLIE_FB_OHNE_SHD : - przyrzymanie LOCK w pilocie zamyka okna oprócz szyberdachu
KOMFORTSCHLIESSEN_VERDECK : - zamykanie dachu cabrio przez przytrzymanie kluczyka w zamku kierowcy
KOMFORTSCHLIESSUNG : - komfortowe zamykanie
KOMFORTSCHLIESSUNG_FB : - zamykanie dachu przez przytrzymanie “zamknij” pilotem, lub zamykanie wszystkich szyb&szyberdachu w nie-cabro
KOMPRESSOR_GEREGELT :
KOMPRESSOR_TRANSPORT_SICH :
KUEHLMITTELUEBERTEMP_CAN : - temperature chłodzenia na linii CAN
KUEHLMITTEL_G_GRENZE : - poziom G cieczy chłodzącej
KUEHLMITTELNIV_FILTERZEIT : - poziom czasu filtra cieczy chłodzącej wert_01
KUEHLMITTELTEMP_ANZEIGEWI : - temperatura cieczy chłodzącej
Ostatnio edytowano 22 Lut 2016 01:07 przez Din76, łącznie edytowano 2 razy
Din76
i druga część
DATENSATZ_1
DBC_MSB :
DEB_TIME_CS_0 :
DEBUG_SIGNAL :
DEF_PIN_20_VOR :
DEF_PIN_37_VOR :
DIAGNOSE_ZWP :
DOPPELKLICK_AUF :
DOPPELKLICK_HEBEN :
DOPPELKLICK_ZU :
DTC_LAMPE :
E53_FAHRZEUG :
E9X_HIMMEL :
EEPROM_SHD :
E_LUEFTER :
EPSILON_DELTA_A :
FLC_DIMMER_OPTION :
FLC_LED_EIN ;
GEBL_OFF_MODE :
HALLSENSOR_VSW72 :
HALLSENSOR_VSW8 :
HBA_DSC_5_7 :
HILLDESC_DSC_5_7 :
HILLDESC_DXC_8 :
HWL_1 :
IB_EIN_HK_AUF :
IK_BUS_TEILNEMER :
K_BUS_FB_SPERREN :
K_BUS_FREI_OHNE :
KLASSIF_DRIFT_ENA :
KLASSIF_LENKM_ENA :
KLEMMENSTATUS :
KL_ENABLE ; - AC
KLS_BEI_AL_AKTIV
LAENDERVARIANTE_LSZ : - Wersja kraju LSZ
LAENDERVARIANTE_RADIO : - Ustawienia regionalne dla radia
LAMPENCHECK_GESICHERT : - Zweryfikowana kontrola świateł.
LATENTWAERMESPEICHER : - Archiwizator ukrytego(?) ogrzewania
LAUTSTAERKE_HINTEN : - Głośność dla tyłu
LAUTSTAERKE_TONGEBER : - Wartość głośności E46/2
LAUTSTAERKE_VORN : - Głośność dla przodu.
LDA_BEI_UNTERSPANNUNG : - podnieś rpm biegu jałowego
LDA_BEI_VERBRAUCHER : - obniż rpm biegu jałowego.
LED_ANSCHLUSS ; - połączenie LED
LED_HARDWARE : - osprzet LEDL
LED_RUECKLICHT_OPTION : - opcje LED tylnich świateł
LENKSAEULENMEMORY : - pamięć pozycji kierownicy
LENKSEITE_1 : - strona elementów kierujących (konsola, kierownica itp.)
LENKSEITE_2 : - strona elementów kierujących (konsola, kierownica itp.)
LENKSEITE_LSZ : - strona włącznika świateł.
LENKSTOCKSCHALTER_ANALOG
LENKSTOCKSCHALTER_KLR : - Włącznik kierowania?
LENK_UEBERSETZUNG : - proporcja (współczynnik) elementów sterujących
LENK_UEBERSETZUNG_LO : - niska proporcja (współczynnik) elementów sterujących
LENKWINKELKENNLINIE: linia poznawania kąta elementów sterujących
LEUCHTDICHTE_EXPO : - koncentracja świateł.
LEUCHTWEITENREG_AUTOM : - automatyczna długość świateł
LEUCHTWEITENREG_DYNAM : - dynamiczna długość świateł
LEUCHTWEITENREGELUNG : - regulacja długości świateł
LICHTBEDIENEINHEIT : - obsługa świateł
LICHTWARNUNG : - ostrzeżenie świateł
LINKSVERKEHR : - ruch lewostronny
LL/RL : - kierowca lewa/prawa strona
LOAD_DUMP : - zgubiony ładunek
LOGIK_HA_SPERRE :
LOGIK_SCHALTER_RESERV :
LOGIK_SWBUNT :
LR_BEI_AL_DRL  RL BS.?
LUFTFEDERUNG :
LUFTVER_AUT_B_ZUEND_EIN_1 : - powietrze dla przekaźników/bezpieczników?
LWR_AUT_EXTERN : - automatyczna kontrola poziomowania świateł
LWR_NEIGUNG_KONSTANTE : - stała regulacji pionowej świateł.
LWR_TREIBER_BEW :
LWR_TREIBER_ERR :
LWR_VORZEICHEN : - wskaźnik poziomowania świateł.
MANUELLE_LWR : - ręczne poziomowanie świateł
MAX_BREMS_UNTERSTUETZUNG : - maksymalne wspomaganie hamowania
MAUT_N_ABBRECH_N_TUER_AUF : - pozwala na obsługę szyb przy otwartych drzwiach jeżeli “not aktive”
MAUT_NUR_BEI_KL15EIN : - Szyby działają kiedy kluczyk w pozycji “ON”.
MAUT_ZU_STOP_N_TUER_AUF : - zatrzymuje obsługę szyb przy otwartych drzwiach jeżeli “not aktive”
MELDUNG_AENDERUNG_DIMMER : - zgłoszenie przy zmianie regulatora światła.
MELDUNG_KATALYSATOR : - zgłoszenie katalizatora
MELDUNG_TASTER : - zgłoszenie czujnika
MEMORY_POS_ANFAHREN : - Pozycja pamięci do jazdy.
MEMORY_POS_SPEICHERN : - Memory position safe.
MEMORY_SP_ABKLAPPEN_GM : - czujnik zmierzchu lusterka stały lub do kluczyka
MEMORY_SPIEGELABKLAPPEN : - czujnik zmierzchu lusterka stały lub do pamięci kluczyka
MEMORY_TIPP_BETRIEB : - obsługa pamięci jednym przyciskiem.
MILANSTEUERUNG :
MIND_ANZ_ZYKL_TIPP_BLK;1 – dotknięcie kierunku (1/3 mrugnięcia)
MIN_WT_SOLLWERT :
MIT_LIN_SCHALTER :
MIT_SRA_EIN_LENKSTOCK :
MIT_WISCHER_SERVICEPOS : - wycieraczki w pozycji serwisowej (pion)
MOTOR_ABKUEHLZEIT : - czas wychłodzenia silnika
MOTOR_ART : - typ silnika
MOTORDIAGNOSE : - diagnoza silnika
MOTOR_NOTPROGRAMM_CAN : -
MOTOR_OELSTAND_PREDRIVE : - poziom oleju na starcie
M_TELEGRAM :
NACHLAUF_ZEIT_H : - pobudka - godzina
NACHLAUF_ZEIT_MIN : - pobudka - minuty
NACHREG_DYN_SLOW :
NAVI_DIST_TO_JUNCTION: - pokaż dystans do manewru (z navi).
NEIGUGSGEBER : - czujnik przechyłu dla alarmu
NG_MOTORVARIANTEN : - odchyłka NG silnika
NIVEAU_1 : - poziom/wartość 1
NLR_AKTIV :
NON-TELEMATIC_E-CALL :
NOTENTRIEGELN_HKL : - awaryjne otwieranie bagażnika.
NOTFUNKTION : - funkcje awaryjne w PDC
NOTLAUF : - rozruch awaryjny.
NOTLAUF_IMMER : - rozruch awaryjny zawsze
NOTSTROMSIRENE : - mocna syrena alarmowa
NSL_AH_US_OPTION : - tylne przeciwmgielne – opcja US
NSL_ALS_STANDLICHT : - halogeny jako parkingowe
NSL_ERSETZT_DEFEKT_BL : - halogeny w zastępstwie STOPów.
NSL_R_NICHT_ANSTEUERN : - tylne przeciwmgielne - zaburzenia
NSW_KEIN_TASTER : - halogeny bez włącznika
NSW_KL_50 : - przednie halogeny na 50 przy ruszaniu
NUR_EIN_TONGEBER :
NUR_KL15_BETRIEB : - PDC pracuje kiedy kluczyk w pozycji pracy kiedy “active”
N_VER_B_ERN_GESCHW_SCHWEL :
OEFFNEN_AUS_GEHOBEN :
OEH_POWER_CONF_0 :
OELNIVEAU_M3 : - poziom oleju M3
OELST_SENS_DEF_WARNUNG : - ostrzeżenie o awarii czujnika poziomu oleju
OELSTAND_MOTOR_CAN : - poziom oleju na linię CAN
OFFENE_FENSTER : - otwarte okna.
OHNE_CENTERLOCK_0 : - wyłacznie zamka centralnego
OHNE_FERNBEDIENUNG_1
OHNE_FERTIGUNGSMODE :
OHNE_FH_BF_HINTEN_0 :
OHNE_FH_BF_VORNE_0 :
OHNE_FH_FA_HINTEN_0 :
OHNE_GIERRATE :
OHNE_IB_0 :
OHNE_INTERVALLBETRIEB :
OHNE_POWERDOWNMODE : - bez samoczynnego opuszczania
OHNE_SERVICEMODE : - bez trybu serwisowego
OHNE_SRA_0 :
OHNE_TRANSPORTMODE : - bez trybu transportowego
OHNE_VA_ZEITEN_0 :
OHNE_WISCH_BEI_WASCH
OPT_ENTRY_HELP :
OPTIMIERTE_SCHLIESSFKT
PANIC_CLOSE : - przytrzymanie zamknięcia na pilocie włącza alarm
PANIC_FREIGABE_CAS :
PANIC_FREIGABE_KL15 :
PANIK_MODUS : - tryb paniki
PARK/NEUTRAL_EINGANG : - przycisk ominięcia bezpieczeństwa sprzęgał&pozwala na start przez EWS podczas parkowania
PASSIVES_DWA_HORN :
PAUSE_ZW_SPRITZIMPULSE : - pauza dla spryskiwaczy.
PDC_AKTIV/DEAKTIV : - aktywacja PDC
PDC_EIN_BEI_KL15 :
PDC_SCHALTER : przycisk PDC
PHASE_AUS_GEDIM_LICHT_AUS :
PHYSIOLOGIEANPASSUNG_1 :
PIKTOGRAMM_ERWEITERT : - grafika sygnalizująca status świateł drzwi (żarówki)
PIN_5_10_AHM_ERS_FU_GESP :
PIN5_10_BFD :
PIN_20_ALS_FRA_LI_VO_2
PIN_29_30_AHM_ERS_FU_GESP :
PIN29_30_BL_NSL :
PIN_37_ALS_FRA_RE_VO_2 :
PM_SCHALTERBLOCK_FOND :
PM_SCHIEBEHEBEDACH :
PM_SITZMEMORY : - pamięć fotela kierowcy
PM_SITZMEMORY_BEIFAHRER : - pamięć fotela pasażera
POWERDOWN_ZEIT : - czas Powerdown
PORTABLE_BT : - przenośny BT
POTI_DIMMER_INVERS :
POTI_LWR_INVERS :
PREFIT_SIM_ENABLED :
PREDRIVE_RPA : - ustawienia lokalne RPA
PRE_MSR :
PRE_VLABS :
PROGRAMMPARAMETER_LSZ_1 to 13: - Parametry ECE (Europa) lub US (USA)
PULS_TIME_OPTION : - opcje pulsacyjne czasu
PWM_ANSTEUERUNG_AL : - wtyczka świateł mijania.
PWM_ANSTEUERUNG_BIXENON : - wtyczka Bi-xenonów.
PWM_ANSTEUERUNG_BL : - wtyczka STOPów.
PWM_ANSTEUERUNG_BL_MITTE – wtyczka 3-go STOPu.
PWM_ANSTEUERUNG_BLK_HI : - wtyczka tylnych kierunków
PWM_ANSTEUERUNG_BLK_VORNN : - wtyczka przednich kierunków
PWM_ANSTEUERUNG_FERNLICHT : - wtyczka świateł drogowych
PWM_ANSTEUERUNG_KZL : - wtyczka oświetlenia tablicy
PWM_ANSTEUERUNG_NSL_LI : - wtyczka halogenów
PWM_ANSTEUERUNG_SL_LI_HI: - wtyczka parkingowych lewy tył
PWM_ANSTEUERUNG_SL_RE_HI : - wtyczka parkingowych prawy tył
PWM_ANSTEUERUNG_SL_VO_LI : - wtyczka parkingowych lewy przód
PWM_ANSTEUERUNG_SL_VO_RE ; - wtyczka parkingowych prawy przód
PWM_ANSTEUERUNG_SL2_RE_HI : - wtyczka parkingowych prawy tył 2
PWM_ANSTEUERUNG_SL3_LI_HI : - wtyczka parkingowych lewy tył 3
PWM_ANSTEUERUNG_SL3_RE_HI : - wtyczka parkingowychprawy tył 3
PWM_ANSTEUERUNG_ZUSTZBLK : - wtyczka dodatkowego kierunku
PWM_WERT2_ALS_BL_AUSGANG : - wyjście STOPu.
PWM_WERT2_ALS_SL_AUSGANG : - wyjście świateł parkingowych.
PWM_WERT2_BLK_ZUSATZFKT – dodatkowy efekt kierunkowskazu
PWM_WERT2_FL_BIXENON : - wert_02= domyślne / wert_01=bixenony&halogeny razem
PWM_WERT2_NSL_ZUSATZFKT : - dodatkowy efekt przeciwmgielnych (halogeny)
PWM_WERT2_SL3_ZUSATZFKT : - dodatkowy efekt parkingowych 3.
QUIT_AKUST_DAUER_10/20/40_MS: - czas sygnału alarmu
QUIT_AKUST_ENTSCH : - dźwięk alarmu przy otwarciu (2x)
QUIT_AKUST_SCHAERF : - dźwięk alarmu przy zamknięciu (1x)
QUIT_AKUST_SCHAERF_KLAPPE : - akustyczne uzbrojenie zamkniętych drzwi
QUITT_A_TEMP_WARNUNG_LSS; - tymczasowe ostrzeżenie o lodzie
QUITT_BLK_SICHERN; - kierunki przy zamknięciu bez alarmu.
QUITT_BLK_ENTSICHERN; - kierunki przy otwarciu bez alarmu.
QUITIMP_SICHERN/ENTSICHER; - potwierdzenie zamknięcia/otwarcia bez alarmu.
QUIT_OPT_ENTSCH : - optyczne powiadomienie otwarcia pilotem (2x kierunki)
QUIT_OPT_SCHAERF : - optyczne powiadomienie zamknięcia pilotem (1xkierunki)
QUIT_OPT_SCHAERF_KLAPPE : - optyczne powiadomienie o zakniętych drzwiach
RCC_UHR : - godzina
RCC_WECKZEIT : - godzina “pobudki”
RDC_ALARM_VIA_HFK : - alarm ciśnienia w kołach przez HFK
RDC_ALARM_VIA_KBUS : - alarm ciśnienia w kołach przez linię K
RDKS : - system monitorowania ciśnienia w kołach
RECHTS_LINKS ; - prawy-lewy.
RECHTSVERKEHR : - prawa (komunikacja/ruch)
REFERENZLAUF_LWR_KL15 :
REGENSCHLIESSEN : - zamykanie przez czujnik deszczu
REGENSCHLIESSENTILT : - zamykanie szyberdachu przez czujnik deszczu
REIFENCONTR_INAKTIV : - melduj/nie melduj aktywność kontroli ciśnienia powietrza
REIFEN_DEFEKT : - uszkodzenie kół
REIFENDRUCKWARNSYSTEM : - ostrzeżenie o przebiciu kół
REIFENTOL_ABGLEICH_ASC : - tolerancja balansu ASC
REIFENTOLERANZABGLEICH : - tolerancja balansu
RFS_AH_OPTION : - opcje swiateł cofania
RL_INNEN_BLINKT : - vizualne ostrzeżenie kierowcy o wstecznym
RR_SCHALTER : - przełącznik cofania
RUECKFAHRGONG : - alarm cofania
RUECKLICHT_INNEN_FEHLT : - informacja o błędzie świateł cofania
RUECKWAERTSGANG_WARN_MED : - typ ostrzeżenia o wstecznym piezo / gong
RUECKWAERTSGANG_WARNUNG : - ostrzeżenie o wstecznym.
SAETT_TIMER_SCHLECHTWEG :
SB_ANHEBEN :
SBE1_STATUS_VERZ_1 :
SBR_US : - przypomnienie o pasach - US
SCA_HECKKLAPPE : - delikatne zamykanie klapy
SCHAERFEN/ENTSCHAERFEN : - zarygluj/odrygluj
SCHALTER2_BL : - przełącznik #2 drugi przełącznik STOPu
SCHALTER_BREMSL_SCHWELLW : - poniesienie wartości przełącznika STOPu wert_01
SCHALTER_BREMSL_WARTEZEIT : - opóźnienie przełącznika świateł STOP.
SCHALTER_R_GANG : - przełącznik biegu wstecznego
SCHALT_KRITERIUM_EWS_3 : - kryteria czujnika immo.
SCHEIBE_ABSENKZEIT : - czas opuszczania szyb.
SCHEIBENABSENK_OHNE_EKS : - otwieranie szyb bez EKS
SCHEIBENINTENSIVREINIGUNG : - zgodność intensywności szyb
SCHIEBEHEBEDACH_TIPP_AUF : - szyberdach jednym przyciskiem - otwieranie
SCHIEBEHEBEDACH_TIPP_HEB : - szyberdach jednym przyciskiem - uchylenie
SCHIEBEHEBEDACH_TIPP_SENK : - szyberdach jednym przyciskiem - opuszczanie
SCHIEBEHEBEDACH_TIPP_ZU : - szyberdach jednym przyciskiem - zamykanie
SCHEINWERFERREINIGUNG : - intensywne zmywanie reflektorów co piąte mycie szyb kiedy “active”
SCHRITTMOTOR_UEBERLAUF : - przeciążenie silnika krokowego
SECOND_HARDKEY :
SEL_ZV_SENDER_1 :
SENSOR_REGEN : - czujnik deszczu
SENSOR_VALEO : - czujnik wycieraczek.
SEQ_M_GETRIEBE : - SMG
SERVOTRONIK :
SHD_ACTU_ALLOWED : - moduł dachu
SHD_CFL_ALLOWED :
SHD_CLOUD_ALLOWED : - zaciemnienie dachu
SHD_RESTARTALLOWED : - zezwolenie na restart dachu
SHD_RRD_ALLOWED :
SHD_SKB_OHNE_KL_OE :
SHD_SKB_OHNE_KL_SCH :
SHD_TMON_ALLOWED :
SIA_RESET_KI_TASTE : przerwania kodowania obsługi
SICHERHEITSFAHRZEUG : - bezpieczeństwo pojazdu
SICHERHEITS_FZG : - bezpieczeństwo pojazdu
SIDEBAG_FOND_LINKS_1 : - czułość poduszki bocznej lewej
SIDEBAG_FOND_RECHTS_1 : - czułość poduszki bocznej prawej
SIDEMARKER_US : - tryb US świateł parkingowych
SIM_IN_TELEMATIK_READER :
SITZMEMORY_VERBAUT : - pamięć foteli przerwana (zaburzenie pracy)
SL_3_ERSETZT_DEFEKT_BLK : - 3 światło parkingowe w przypadku awarii kieruku nicht_aktiv
SL_ERSETZT_DEFEKT_BL ; - światła parkingowe w przypadku awarii STOPu nicht_aktiv
SL_ERSETZT_DEFEKT_BLK : - światła parkowania w przypadku awarii kierunków.
SL_INNEN_ALS_TWL : - światło parkowania
SL_VO_ANSTEUERUNG : - przednie światła parkowania aktywowane
SL_VORNE_ALS_ZUSATZ_BLK : - przednie światła parkowania jako dodatkowe kierunki
SMG_S_ANZEIGE :
SOFT ON/OFF : - stopniowe zapalanie/gaszenie oświetlenia wnętrza
SOFTWARE_VERDECK : - oprogramowanie cabrio
SOLLWERT_KORREKTUR_1 : - korekta ustawienia wartości klap
SONDERFHZG_MIT_WSA :
SOS_ACTU_ALLOWED :
SOS_CFL_ALLOWED :
SOS_CLOUD_ALLOWED :
SOS_RESTARTALLOWED :
SOS_RRD_ALLOWED :
SOS_SKB_OHNE_KL_OE :
SOS_SKB_OHNE_KL_SCH :
SOS_TMON_ALLOWED :
SP_BEWERT_OD_ALC_NSW_AUS :
SPERRDIFFERENZREGELUNG : - regulacja różnic szpery
SPERR_VENT_TEST :
SPERR_WLM_TEST :
SPERRZEIT_KL_R_AUS_0.2_S : - czas szpery
SPIEGELEINKLAPPEN : - składanie lusterek
SPIEGELABKLAPPEN : - rozkładanie lusterek
SPIEGELHEIZUNG : - podgrzewanie lusterek
SPIEGELHEIZUNG_VERBAUT : - zaburzenia podgrzewania lusterek (przerwanie)
SPIEGELMEMORY : - pamięć kierowcy dla lusterek
SPIEGELMEMORY_GM : - pamięć pozycji lusterek.
SP_MOTOR_BEWERTEN :
SP_MOTOR_F_EINTRAG : - błąd na wejściu silnika (lusterek)
SP_MOTOR_STOP : - stop silnika (lusterek)
SPG_NACHREGELUNG : - regulacja lusterek
SPG_NACHREGELUNG_LANGSAM :
SPG_NACHREGELUNG_ZUSATZ :
SPRACHE : wybór języka
SPZ_PROG :
SRA_L322_RELAY :
SRA_MIT_WASCH_WISCH_SW
STANDHEIZUNG : - webasto
STANDHEIZUNG_KONZEPT -
STANDLICHT_ALS_BREMSLICHT : - światła parkingowe jako STOPy. nicht_aktiv
STANDLICHT_ALS_NSL_LINKS : - światła parkingowe jako przeciwmgielne lewa. nicht_aktiv
STANDLICHT_ALS_NSL_RECHTS : - światła parkingowe jako przeciwmgielne prawa.
STANDLICHT_VORNE : - ringi
STANDLUEFTUNG : - ogrzewanie parkingowe
STANDRUECKSCHALTUNG : warunek resetowany przy zatrzymaniu
STATUS_LESEN : - status odczytu
STEIG_KL58_T_PER_D :
ST3_SCHWEL:
TACHO_SKALA_ENDWERT - końcowa wartość prędkościomierza
TAGFAHRLICHT_ECE : - światła dzienne ECE [ringi]
TAGFAHRLICHT_DAN : - światła dzienne Dania?
TAKTUNG_HHS :
TAKTEN HIGH LOW ANZEIGE : - HIGH/LOW informacja taktowania
TAKTUNG_IB :
TAKTUNG_VERBRAUCHERABSCHA :
TANK_KENNLINIE Tank : - kalibracja pojemności zbiornika 60_l_literskala
TANK_MITTLUNGSZEIT : -cześtotliwość pomiaru przepływu paliwa 5_sec
TANK_SCHWELLE_AUF/AB : - światło rezerwy 6_l
TANK_SCHWELLE_RESERVE : - próg rezerwy 8_l
TANK_SICHERHEITSFAKTOR : - czynnik bezpieczeństwa zbiornika 1.3
TANK_VORHALT_REICHW : - zasięg na zbiorniku
TASTE_UEBER_CAN : - przycisk/czujnik poprzez linię CAN
TASTER_NSL : - czujnik tylnich przeciwmgielnych
TASTER_NSW : - czujnik halogenów
TASTER_NSW_NSL : czujnik przeciwmgielnych + halogeny
TAXI_ENABLE : - moduł taxi.
TELEMATIK :
TELEGRAMM_ZEIT_ZYKLUS : - długośc cyklu Telegram.
TEMPCFLUSEOUTER : - temperatura zewnętrzna
TEMPCFLUSESENSOR : - czujnik temperatury zewnętrznej
TEMP_DRUCKPUMPE : - temperatura pompy ciśnienia
TEMPERATUR_EINHEIT : - jednostka temperatury (°C/°F)
TEMPERATUR_GRENZE : - granica temperaturay.
TEMP_FOND : - czułość temperatury
TEMPTMONUSEOUTER :
TEMPTMONUSESENSOR :
TESTBETRIEB : - test rozruchu
TEST_OD_ST2_OHNE_NSW
TNK_DECKEL_WARNUNG : - ostrzeżenie otwartej klapki wlewu
TP_FUNKTION : - funkcje radia ?
TRAKTIONDIFFERENZREGELUNG : regulowanie różnic trakcji
TREIBER_BEWERTEN : - rozpoznawanie kierowcy.
TREIBER_F_EINTRAG : - zapisywanie kierowcy
TREIBER_STOP_OD_ALC_RE_OK :
TRIGGERSCHALTER_1 : - przełącznik spustowy
UEBERLAUFSCHRITTE_BEI_0 : - przepełnienie krokowe przy 0
UEBERLAUFSTEPS_BEI_100% : - przepełnianie krokowe przu 100%
UEBER_ROLLSENSOR_1 :
UEBERSPANNUNGSSCHUTZ : - zabezpieczenie antyprzepięciowe (natężenie)
UEBERSPG_ABSCHALT_58G ;
UEBERSPG_ABSCHALT_BL : - zabezpieczenie antyprzepięciowe kierunków
UEBERSPG_ABSCHALT_NSL : - zabezpieczenie antyprzepięciowe halogenów
UEBERSPG_ABSCHALT_RFS : - zabezpieczenie antyprzepięciowe światęł cofania
UEBERSPG_ABSCHALT_SL : - zabezpieczenie antyprzepięciowe św. postojowe
UEBERSPG_ABSCHALT_SL_H :
UEBERSPG_ABSCHALT_SL_HI : - zabezpieczenie antyprzepięciowe św. tylnych
UEBERWACH_FENSTER_BF_HI : - nadzór szyby pasażera tył
UEBERWACH_FENSTER_F_VO : - nadzór szyby kierowcy przód
UEBERWACH_HECKSCHEIBE : - nadzór szyby tylnej
ULF_EIN_AUS : - zabezpieczenie antyprzepięciowe (napięcie)
UMLUFT MEMORY : - obieg wewnętrzny powietrza (pamięta czy był włączony przed zgaszeniem auta)
UNTERSTEUERUNGSALGORYTHM : - algorytm przesterowania
US_CALL_SERVICE_CENTER : - centrala systemu serwisowego US
USE_SOS :
VA1_SPERRE_BEI_FEHLER :
VA_2 :
V_ABHAENGIG :
VARIANTE_LSZ : - Wersja LSZ.
VENTIL_HALTESTELLUNG : - pozycja zatrzymania zaworu
VERBRAUCH D1 : - jednostki zużycia (L/100Km,mpg-Eng,mpg-USA,Km/L)
VERDECKKLAPPE_VORHANDEN : - obecność składanego dachu
VERL_ALARMZEI_WAEHR_ALARM :
VERRIEGELN_AUT_AB_X_KMH : - automatyczne ryglowanie po przekroczeniu X Km/h
VERRIEGELN_AUT_NACH_2_MIN : - ponowne zamknięcie po 2 min jeżeli auto otwarte I nie otwarto drzwi
VERRIEGELN_SITZLEHNE_FA_1 : - blokada siedzisko-oparcie
VERRIEGELUNGSSCHWELLE : - wybór prędkości automatycznego ryglowania
VERZUG_ENTR_HECKKLAPPE : - opóźnienie otwarcia tylnej klapy
VERZUG_PANIK_MODUS_0.2_S : - opóźnienie trybu Panic 0.2 sekundy.
VOLUMENDURCHFLUSSPARA_2 :
VORGLUEHEN/KAT_HEIZEN_CAN : - dogrzewanie
VKBODEN_ERKENNUNG :
VMAX_BESCHLEUNIGUNG : - limit przyspieszania
VMAX_BREMSEN : - limit hamowania
VOLUMENDURCHFLUSSPARA : - głośność przy parametrze przepływu
V_VAR_SPERRE_BEIKLAPPEN : - parametr pracy zamka
WARMUEBERWACH_ZUSATZ_BLK: - ciepły test zewnętrznych sygnałów skrętu
WARMUEBERWACHUNG_AL : - ciepły test żarówek mijania
WARMUEBERWACHUNG_AL_L : - ciepły test żarówek mijania
WARMUEBERWACHUNG_BL_MI : - ciepły test żarówek świateł STOP
WARMUEBERWACHUNG_BLK_HI : - ciepły test żarówek tylnych kierunków
WARMUEBERWACHUNG_BLK_VO : - ciepły test żarówek przednich kierunków
WARMUEBERWACHUNG_FL : - ciepły test żarówek świateł drogowych
WARMUEBERWACHUNG_KZL_LI : - ciepły test żarówek oświetlenia tablic
WARMUEBERWACHUNG_NSL_LI : - ciepły test żarówek przeciwmgielnych.
WARMUEBEWARMUEBERWACHUNG_RL_LI :
WARMUEBERWACHUNG_RL_RE: - ciepły test żarówek cofania prawe
WARMUEBERWACHUNG_SL_LHI : - ciepły test żarówek pozycyjnych lewy tył
WARMUEBERWACHUNG_SL_RHI : - ciepły test żarówek pozycyjnych prawy tył
WARNBLINKER : - kierunki ostrzegawcze, 1x lub 2x mignięcie
WARN_MEDIUM_AUSSENTEMP : - ostrzeżenie piezo o temperaturze zewnętrznej
WARN_MEDIUM_GURT : - ostrzeżenie piezo o pasach
WARN_MEDIUM_PARKBREMSE : - ostrzeżenie piezo o ręcznym
WARN_MEDIUM_RDKS : - ostrzeżenie piezo PDC
WARN_MEDIUM_ZUENDSCHL : - ostrzeżenie o zapłonie
WARNUNG_GESCHW_LIMIT : - ostrzeżenie o limicie prędkości
WARNUNG_MOTOR_OELSTAND : - ostrzeżenie o poziomie oleju
WARTEN_SCHEIBEN_ABGESENK : - poczekaj na opuszczenie szyb przed otwarciem dachu
WAKEUP_GENERELL : - ogólna “pobudka”
WAKEUP_TAGE : - dzień “pobudki”
WAKEUP_ZEIT : - godzina “pobudki”
WASSERPUMPE : - pompa wody
WASSERSTOFF_FZG :
WEG_DURCHSCHNITT : - średnia jednostka drogi
WEG_EINHEIT : - jednostka odległości ( mls lub km)
WEGFAHRSICHERUNG_AUTOM : - Automatyczne unieruchamianie pojazdu
WEGSIGNAL_SERVO_ABS :
WE_MODE :
WISCHER_RUECK_GESCHW : - prędkość tylnej wycieraczki.
WISCHERINTERVALL: - wybór przerwania wycieraczek
WISCHERMOTOR_RSK : - silnik wycieraczek
WISCHERPOTI : - taktowanie wycieraczek
WISCHER_VOLLEND_KLR_AUS ;
WINDSCHOTT :
WINDSCHOTT_OPT :
XDT :
XENONLICHT_ZUEND_OPTION : - Zapłon ksenonów
XENON_TEST : - test ksenonów.
XENON_TIME : - czas ksenonów.
XENON_TIMEOUT : - limit czasowy ksenonów.
ZEIT_EINHEIT : - Tryb czasu (12H /24H)
ZEIT_BIS_AUTOM_SPERREN : - czas przed automatycznym zamknięciem.
ZEITDAUER_BIS_ABSCHALTUNG : - czas przed zamknięciem.
ZEIT_KALT_PULSE : - czas zimnego sygnału. wert_01
ZEIT_KALT_PULSE_QUICK : - szybki czas zimnego sygnału. wert_01
ZEIT_KALT_RUNDEN : - czas zimnego obrotu.
ZEIT_TUER/SCHLIESSZEIT : - czas zamknięcia drzwi
ZKE : - główna elektronika nadwozia
ZUHEIZUNG : - podgrzewanie wstępne diesla
ZUENDSCHL_GONG_R_EIN : - pozostawiony kluczyk - gong
ZUENDSCHLUESSEL_KBUS : - pozostawiony kluczyk na linię K
ZUENDSCHLUESSEL_WARNUNG : dżwięk + komunikat pozostawiony kluczyk w stacyjce
ZUSATZWASSERPUMPE : - dodatkowa pompa wody
ZUWACHS_TASTVERH_KL_58G :
ZYKLUS_KALT_RUNDEN_QUICK : - cycle zimnych obrotów QIUCK.
ZV_AGGREGATE_TYP : typ systemu zamka centralnego
ZV_BEDIENST_BT_DISABLE :
ZV_ENTR_SCHL_BEI_DWA_AKT :
ZV_SELEKTIV : - odrygluj tylko drzwi kierowcy jeżeli [aktive] lub wszystkie jeżeli [nicht aktive] dla klucza
ZV_VR_BEDIENSTELLE_HECK : -
Din76
Postprzez bmw-power » 14 Gru 2014 21:51
Dzięki din76 Porównam ze swoimi, dobra robota
bmw-power
Postprzez luki244 » 21 Gru 2014 23:26
swietna sprawa, tez chce zaczac z ncs dummy , jutro napisze bo mam jedno pytanie :)
pozdro
luki244
Dołączenie: 03 Lis 2014 23:11
Moje BMW: F10 520d 2010 :)
Powróć do Diagnoza komputerowa
