BMW F10 525dx working fluids and brakes
Hi everyone, recently bought BMW 5 series F10 525D xDrive, 2014, 150000 kilometers. I think that i need to change coolant and brake pads besides oil in engine and transmission.
1) Could you recommend which coolant should i select for this car?
1) Could you recommend which brake pads are better for me?
1) Could you recommend which brake fluid should i select for this car?
1) Could you recommend which brake discs should i select for this car?
Links on allegro or etc. will be great!
Thank you very much!
Coolant : https://czescidobmw.pl/plyn-do-ukladu-chlodzenia-motul-auto-cool-expert-5l--auto,1cool,1expert,15l
Brake fluid: https://czescidobmw.pl/plyn-hamulc-dot4-1l-sl6-03-9901-6402-ate--03,99901,66402,2ate
Brake pads & discs: There are two versions of the front brake pads and discs, regular and reinforced, so you must provide the VIN in the store.
