Silniki informacje techniczne bmw
MiloszGD
Mam dostęp do informacji technicznych bmw na temat budowy , parametrów itp związanych z silnikami.
Lista silników:
N13
N20
N42
N52
N53
N54
N55
N62
N63
N63TU
N73
N74
M47D20
M47D20TU
M57
M57TU
M57TU EU4
M67
M67TU
N47
N47TU
N57
N57TU
Poniżej przykładowy spis treści dla M47D20
1 M47D20 VP44 3
1.1 Introdution 3
1.2 Objectives 3
1.3 Technical features 4
1.4 Technical data 4
2 Engine components 7
2.1 Support spar concept 7
2.2 Crankshaft seal 8
2.3 Flywheel 8
2.4 Connecting rods with bearings 8
2.5 Pistons 9
2.6 Cylinder head 10
2.7 Vacuum pump 11
2.8 Cylinder head gasket 12
2.9 Cylinder head cover 13
2.10 Chain drive 15
2.11 Valve gear 17
2.12 Valves and valve springs 17
3 Ancillary components and belt drive 18
3.1 Belt drive 18
3.2 Torsionalvibration damper 18
3.3 Starter motor 18
3.4 Alternator 18
3.5 A/C compressor/retaining fixture 18
3.6 Engine mount 18
4 Oil circuit/lubricating systems 19
4.1 Oil pump 19
4.2 Oil filter head/filter, new 20
4.3 Oil cooling 21
4.4 Oil pan 21
4.5 Oil spray nozzles 22
5 Cooling system 23
5.1 Coolant circuit 23
5.2 Auxiliary heater 24
5.3 Thermostat 24
5.4 Couplings for coolant hoses 25
5.5 Radiator 26
6 Distributor pump VP44 27
6.1 Functional principle 27
6.2 Fuel delivery system 30
6.3 High pressure generation/distribution 32
6.4 Injection timing 36
6.5 Pump control 38
6.6 Angle of rotation sensor 39
6.7 Summary 40
2
Contents Page
7 Intake air and exhaust systems 41
7.1 Intake silencer with air cleaner 41
7.2 Intake system 41
7.3 Exhaust turbocharger 41
7.4 Functional principle of a turbocharger with VNT 42
7.5 Charge air cooling 45
7.6 EGR valve 46
7.7 Electropneumatic exhaust backpressure transducer 46
7.8 Arrangement of vacuum lines 47
7.9 EGR cooling 47
7.10 Exhaust system 49
8 Digital diesel electronics (DDE 3.0) 50
8.1 Review of DDE control units 50
8.2 Comparison of DDE 3.0/2.2 control units 51
8.3 Engine management 52
8.4 CAN interfaces 52
8.5 Fuel system 53
8.6 Fuel filter 54
8.7 Presupply pump control 55
8.8 Injection lines 56
8.9 Injection nozzle (two-spring nozzle holder) 56
8.10 Matching injection pump to the control unit 58
8.11 Preheating relay 58
8.12 Glow plugs (heater plugs) 58
9 Service information 59
9.1 Removing distributor-type injection pump 59
9.2 Installing distributor-type injection pump 60
9.3 Adjusting and checking distributor-type injection pump 61
9.4 Checking and adjusting timing 62
9.5 Notes on turbocharger 62
10 Brief description of common rail 64
10.1 History 64
10.2 Introduction 64
10.3 Requirements 65
10.4 Functional principle 66
10.5 Component comparison 67
Kto co potrzebuje proszę dać znać podając maila.
  • 5 miesięcy temu...
