M5 V10 Bi-compressor 730 KM
A
G-Power Hurricane M5 V10 Bi-compressor ASA 730 KM
2 x ASA T1-12 superchargers including overrunning clutch, oil supply supercharger, twin flow optimized, large volumetric fresh air intakes made from carbon fibre, twin racing air filters, twin high capacity, water cooled intercooler system including low temperature circuit, twin ultrastiff CNC shaped supoercharger bracket systems including extended belt drive, pneumatic controlled dynamic boost control, additional ECU controlled throttle butterflies optimal thermodunamic conditions, 10 x compression reducing, forged pistons, 10 x larger fule injectors, G-POWER performance exhaust system made from stainless steel, custom made software for the standard BMW ECU and with adjusted SMG control (OBD is not adfected).
0-100 km/h in < 4,2 s
0-200 km/h in < 10,4 s
0-300 km/h in < 29,5 s
http://photos-a.ak.facebook.com/photos-ak-sf2p/v136/126/34/507102540/n507102540_430968_8367.jpg
%5B640%3A480%5Dhttp%3A//img267.imageshack.us/img267/9549/dsc00141copypf0.jpg
%5B640%3A480%5Dhttp%3A//img267.imageshack.us/img267/1014/dsc00212um6.jpg
%5B640%3A480%5Dhttp%3A//img440.imageshack.us/img440/4729/dsc0022yx4.jpg
%5B640%3A480%5Dhttp%3A//img252.imageshack.us/img252/3182/dsc00231sy1.jpg
%5B640%3A480%5Dhttp%3A//img402.imageshack.us/img402/7592/dsc0031ms0.jpg
%5B640%3A480%5Dhttp%3A//img402.imageshack.us/img402/8558/dsc0030qh7.jpg
%5B640%3A480%5Dhttp%3A//img253.imageshack.us/img253/7320/dsc00471oc9.jpg
%5B640%3A480%5Dhttp%3A//img108.imageshack.us/img108/7056/dsc00591va0.jpg
%5B640%3A480%5Dhttp%3A//img253.imageshack.us/img253/9311/dsc00612lm7.jpg
%5B640%3A480%5Dhttp%3A//img108.imageshack.us/img108/6731/dsc00661bz4.jpg
%5B640%3A480%5Dhttp%3A//img249.imageshack.us/img249/8971/dsc00671mj9.jpg
%5B640%3A480%5Dhttp%3A//img179.imageshack.us/img179/6981/dsc0074wu4.jpg
%5B640%3A480%5Dhttp%3A//img101.imageshack.us/img101/259/dsc0072kf8.jpg
%5B640%3A480%5Dhttp%3A//img515.imageshack.us/img515/4673/dsc0076781tonemappedel9.jpg
%5B640%3A480%5Dhttp%3A//img443.imageshack.us/img443/4792/dsc0079jw5.jpg
%5B640%3A480%5Dhttp%3A//img513.imageshack.us/img513/1218/dsc0089nr0.jpg
%5B640%3A480%5Dhttp%3A//img204.imageshack.us/img204/4379/dsc008123tonemappedpb6.jpg
%5B640%3A480%5Dhttp%3A//img443.imageshack.us/img443/6892/dsc0116qn4.jpg
%5B640%3A480%5Dhttp%3A//i2.tinypic.com/6q26qmg.jpg
%5B640%3A480%5Dhttp%3A//i1.tinypic.com/6ut692t.jpg
:cool2: :mrgreen:
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art" - Chris Bangle
No to mam nowe tapetki na następne tygodnie :mrgreen:
A co do tematu, to niesamowite auto :jawdrop:
Przeczytaj moje artykuły:
G-Power M5 V10 Bi-compressor EVO 2 Hurricane
%5B640%3A480%5Dhttp%3A//www.m5board.com/temp/gpower/g7.JPG
Evo II: 2 x ASA T1-12 superchargers including overrunning clutch, oil supply supercharger, twin flow optimized, large volumetric fresh air intakes made from carbon fibre, twin racing air filters, twin high capacity, water cooled intercooler system including low temperature circuit, twin ultrastiff CNC shaped supoercharger bracket systems including extended belt drive, pneumatic controlled dynamic boost control, additional ECU controlled throttle butterflies optimal thermodunamic conditions, 10 x compression reducing, forged pistons, 10 x larger fule injectors, G-POWER performance exhaust system made from stainless steel, custom made software for the standard BMW ECU and with adjusted SMG control (OBD is not adfected).
%5B591%3A480%5Dhttp%3A//www.m5board.com/temp/gpower/g3.JPG
Ludzie dziela sie na szczesliwych, i na tych którzy nie maja BMW.
http://img247.imageshack.us/img247/4272/jpg4bb8.jpg
http://www.motostat.pl/user_images/2857/icon3.png
To samo chciałem napisać :roll2:
Po wyniku 0-100 wyraźnie widać, że auto ma duże kłopoty z przeniesieniem tej mocy na asfalt. Znacznie słabsze auta mają tu lepsze wyniki. Taka moc w tego typu aucie zwyczajnie się marnuje.
Wg mnie bezsensowny wyścig zbrojeń..
pzd.
