Skróty stosowane w diagnostyce Bmw
nerwus
BMW Technical Acronyms
A - processed vehicle speed signal
A - "out" (Aus)
AB - Airbag
ABL - Brake system warning Lamp (2 color)
ABS - Anti-lock Braking System
AC - Air Conditioning (from ETK)
ACC - Active Cruise Control
ACS - Active Comfort Seats
ADB(X) - Automatic Differential Braking
ADS - engine intake air control
ADV - windshield wiper pressure control
AEGS - Automatic Electronic Gearbox Control (also EGS)
AFM - Air Flow Meter
AGD - suction silencer (from ETK)
AGR - emission reduction
AGS - Adaptive transmission control
AG - Automatic Gearbox (transmission)
AHK - Active rear-axle Kinematics
AHK - trailer hitch (from ETK)
AHM - trailer Module (not for US models)
AHPS - Advanced HPS
AIC - Automatic Interval Control (rain sensor)
AKF - activated carbon canister (from ETK)
AKS - Active head restraint
AKS - pressure regulating device (from ETK)
ALC - Automatic Light Control
ALR - Automatic Lamp Range Adjustment
AMM - Air Mass Meter
AMP - radio system AMPlifier
ARI - car radio information system (from ETK)
ARS - Active Roll Stabilization
ASC - All Season traction
ASC-EZA - ASC w/ engine timing and injection intervention
ASC+T - ASC+ Traction control
ASK - Audio System controller (Kontroller)
ASR - self starter block relay (from ETK)
AST - Automatic Slip control (marketing term)
AT - remanufactured part (from ETK)
AT - Antenna (from ETK)
ATF - Automatic Transmission Fluid (from ETK)
ATL - exhaust gas turbo charger (from ETK)
AUC - Automatic air recirculation
AUT - AUTomatic transmission (from ETK)
AVT - Antenna amplifier Tuner
AZD - tightening torque specifications (in TIS)
A/D – Analog/Digital
B - Benzene (gasoline)
BAT - BATtery (from ETK)
BC - Board Computer
BC1 - Body Controller 1
BL - Brake Light (from ETK)
BLS - Brake Light Switch
BMBT - Board Monitor
BS - Block diagram
BST - Battery Safety Terminal
BVA - Brake pad wear indicator (from ETK)
BZM - center console control center
BZMF - center console control center, rear
CAN – Controller Area Network (Multiple ECU Controller)
CAN-Bus - Controller Area Network (bus)
CANH-Bus - CAN bus, High
CANL-Bus - CAN bus, Low
CANP - fuel tank ventilation valve
CAS - Car Access System
CBC - Corner Braking Control
CBS - Condition Based Service
CCM - Check Control Module
CD - Control Display
CDC - Compact Disk Changer
CDS - CD player (from ETK)
CEL - CELsius (from ETK)
CIM - Chassis Integration Module
CO - Carbon monOxide (from ETK)
COMBI – Electronic Instrument Cluster
CON - CONtroller
CU - Copper (from ETK)
CVM - Convertible top Module
CVT - Constantly Variable Transmission
CW - drag coefficient (from ETK)
D1 - Xenon light/ gas discharge (from ETK)
D-Bus - Diagnosis bus (same as TXD)
DBC - Dynamic Brake Control
DBS - Dynamic Braking System
DCS - Dealer Communication System
DE – Diagnostic Unit
DD - Dynamic motor Drive
DDE - Digital Diesel Electronics
DIN - German industrial standards
DIS - Diagnosis and Information System
DISA - Differential air intake control
DIVA - continuously variable length intake runners
DK - throttle housing/valve
DKB - throttle w/ brake intervention
DKE – Throttle Increase
DKI - throttle position
DKR - throttle reduction
DKT - throttle position signal
DKV - preset throttle position value
DME - Digital Motor Electronics
DM-TL - Diagnostic Module Tank Leakage
DOHC - Double Over Head Camshafts (from ETK)
DS - gasket set (from ETK)
DSC - Dynamic Stability Control
DSP - Digital Sound Processing
DTC - Diagnostic Trouble Code (SAE)
DTC - Dynamic Traction Control
DWA - theft deterrent system
DWS - tire pressure Warning System
DZM - revolution counter (from ETK)
E - "in" (Ein)
EBA - installation instructions (from ETK)
EBV - Electronic Brake force proportioning
ECE - European market version (from ETK)
ECM - Engine Control Module (SAE term)
ECU - Electronic Control Unit
EDC - Electronic Damper Control (from ETK)
EDR - Electronic throttle control
E-KAT - Electrically heated catalytic converter
EZA - see ASC-EZA
ECO - Controller for I-Drive system
EDC - Electronic Dampening Control
EDC-K - Electronic Dampening Control - Continuous
EDK - Electronic throttle valve
EDS - pressure regulator
EFH - Electric window lifter (from ETK)
EGS - Electronic transmission control
EH - Electronic-Hydraulic
EHC - Electronic Height Control
EKM - Electronic body Module
EKP - Electric fuel Pump
ELV - Electronic steering lock
EM - Electro-Mechanical
EMF - Electro-Mechanical parking brake
EML - Electronic Motor Load regulation
EMV - Electro-Magnetic sensitivity (from ETK)
EO - component location
EPC - Electronic Parts Catalog (also ETK)
EPROM - Erasable/ Programmable chip Memory (from ETK)
ETK - Electronic parts catalog (also EPC)
ETM - Electrical Troubleshooting Manual
ESS - Electronic anti-theft device
EV - injection Valve
EWS - Electronic drive-away protection
FB - Function description
FBC - Fading Brake Control
FBD - remote control services
FBZV - radio frequency locking system
FGR – Vehicle Speed Control (Cruise Control)
FH - window lifter
FHK - rear Heater/ air conditioner
FLC - automatic Light Control
FRU - Flat Rate Unit
FS – Crash Sensor
FZV - central lock receiver
GAL - speed dependent sound volume
GM - General Module
GMR - yaw moment control
GPS - Global Positioning System
GRII - cruise control
GRS - rotation Rate Sensor
GS – Belt Tensioner
GWK - torque converter lock-up control
H - "rear" (Hinten)
H2 - Xenon headlights
HA - rear Axle (from ETK)
HC – Hydro Carbon
HD - Heavy Duty (from ETK)
HDC - Hill Decent Control
HFM - Hot Film air mass Meter
HG - manual Gearbox (transmission)
HKL - Hydraulic trunk lid Lift
HLM – Hot Wire Air Mass Meter
HPS - Head Protection System
HR - Heater control (from ETK)
HVA - Hydraulic Valve Adjuster (from ETK)
Hz – Hertz (Cycle)
I-Bus - Information bus
IB - Interior lighting control signal
IHKA - automatic Heating and A/C
IHKAF - IHKA w/ micro filter
IHKR - regulated Heating and A/C
IHKRF - IHKR w/ micro filter
IHKS - standard Heating and A/C
IHPD - Internal High Pressure Deformation
IHR - Integrated Heater control (from ETK)
IKE - Instrument cluster Electronics
ILH - Interior Lighting, rear
ILV - Interior Lighting, front
IMS - Instant Mobility System (from ETK)
IR – Infrared
IRS – Infrared Locking System
ISC – Idle Speed Control
ISIS - Intelligent Safety Integration System
ISN - Individual Serial Number
ISOFIX - standardized mounts for child restraints
ITS - head airbag assembly/ Inflatable Tubular Structure
IVM - Integrated power supply Module
K-Bus - body bus (Karosserie)
KAT - catalytic converter
KATON - converter creating (signal)
KD - Kick-Down
KHI - interface for headphones
KL - terminal designation
KL15 - run bus (ignition switch run position)
KL30 - battery bus (hot at all times)
KL31 - ground bus (chassis ground)
KL50 - start bus (ignition start position)
KLR - accessory bus
KO - compressor "on" signal
KOMBI - instrument cluster
KOREL - compressor relay signal
KR – Contact Ring
KSK - Knock Sensor
KVA - fuel consumption signal/value
KW - crankshaft
KW - KiloWatt (from ETK)
LCM - Lamp Check Module
LDP - Leak Diagnosis Pump
LEV - Low Emissions Vehicle
LEW - Lateral acceleration sensor
LHD - Left-Hand Drive (from ETK)
LKM - Lamp control Module
LL - closed throttle
LM - Light Module
LMM - air flow meter/sensor
LMR - Light alloy wheel
LRA - vertical headlight aiming
LSM - steering column memory
LSZ - Lamp Switching center
LVA - air supply system (for EHC system)
LWR - vertical headlight aim control
LWS-5 - steering angle sensor
M-Bus - IHKA/IHKR stepper motor bus
MAL - center armrest
MBC - Maximum Brake Control
MDK - Motorized throttle valve/system
MFL - Multi-Function steering wheel
MFC - Multi-Function Controller
MFU - Multi-Function Clock
MID - Multi-Information Display
MIL - Malfunction Indicator Lamp (SAE), "check engine" Lamp
MIR - Multi-Information Radio
MMC - Multi-Media Changer
MoDiC - Mobile Diagnostic Computer
MOST-Bus - Media Oriented System Transport bus
MRS - Multiple Restraint System
MSR - engine drag torque Regulation
MV - Magnetic Valve (solenoid Valve)
n-ab - rotational speed, transmission (rpm)
n-mot - rotational speed, engine (rpm)
NAVI - Navigation module
NG - New Generation (as in N73 engine)
NG - tilt sensor
NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK)
NSD - rear muffler (from ETK)
NSL - rear fog Lamp (from ETK)
NSW - fog lamp (from ETK)
NTC - Negative Temperature Coefficient
NW - camshaft (from ETK)
OBC - On-Board Computer
OBD - On-Board Diagnosis (SAE)
P/N – Park/Neutral position
P-Bus - Periphery bus
PB - Pin assignments
PBS - Parts Bulletin System (in TIS)
PDC - Park Distance Control
PGS - Passive Go System
PM - Power Module
PP – Impact Pad
PTC - Positive Temperature Coefficient
RLS - Rain-Light Sensor
PWG - Pedal position sensor/ potentiometer
RA - Repair instructions (in TIS)
RAM – Random Access Memory
RAL - Aluminum wheels (from ETK)
RAL - standard color (from ETK)
RDC - tire pressure Control
RDS - Radio Data-broadcast System
RDW - tire pressure Warning
RHD - Right-Hand Drive (from ETK)
RM - Relay Module
ROZ - Research Octane rating/ fuel grade (from ETK)
RPA - tire puncture warning (from ETK)
RPS - Rollover Protection System
RS - Repair kit (from ETK)
RSW - back-up lamp (from ETK)
RXD - wake-up Diagnosis line
RZV - direct stationary ignition
SASL - Satellite, A-pillar left
SASR - Satellite, A-pillar right
SAV - Sport ACTIVITY Vehicle
SB - fuse assignments
SBE - Seat occupancy detector/sensor
SBFH - Seat module, passenger-side rear
SBSL - Satellite, B-pillar left
SBSR - Satellite, B-pillar right
SBT - SI techniques/ tech reference information (in TIS)
SCA - Soft Close Automatic/Actuator
SD - sliding roof (from ETK)
SD - silencer/ muffler (from ETK)
SE - Special Equipment (from ETK)
SES - voice recognition System
SFAH - Seat module, driver's side rear
SFZ - Satellite, vehicle center
SG - control unit
SGS - Seat integrated belt System
SHD - sliding/ lifting roof (from ETK)
SHD - Sunroof module (also SHDM)
SI - Service Information (in TIS)
SIA - Service Interval system (ver. I, II, III, IV, etc.)
SII - Service Interval Indicator
SIL - SILicon (from ETK)
SIM - Safety Information Module
SINE - Siren/tilt sensor
SKD - Steel sliding roof (from ETK)
SKHD - Steel sliding/ lifting roof (from ETK)
SM - Seat Module
SM/SPM - Seat/Mirror Memory
SMBF - Seat Module, passenger side
SMFA - Seat Module, driver's side
SMG - Sequential Manual Gearbox
SP - Schematic
SRA - headlight/fog light cleaning
SRS - Supplementary Restraint System
SSD - Steel sliding roof (from ETK)
SSH - Seat Satellite, rear seat
ST - connector views
Steptronic - transmission shift control
STVL - Satellite, left front door
STVR - Satellite, right front door
SVS - Speech processing System
SWR - headlamp cleaning system (from ETK)
SWZ - Special tool listings (in TIS)
SZL - Switch center, steering column
SZM - central switch center Module
TAGE - door handle Electronics
TCM - Transmission Control Module
TD - engine speed signal (ignition pulse)
TD - Technical Data (in TIS)
TE - fuel evaporation control
TEL - TELephone control unit
TEV - evaporative purge control
THZ - Tandem master cylinder (from ETK)
ti - Injector "on" Time (duration)
TIS - Technical Information System
TL - part throttle / load signal
TLEV - Transitional Low Emission Vehicle
TMBFT - door Module, passenger side
TMBFTH - door Module, passenger side rear
TMFAT - door Module, driver's side
TMFATH - door Module, driver's side rear
TP - Tandem Pump (from ETK)
TPS - Throttle Position Switch/Sensor
TR - engine speed signal (rpm)
TR - TRansistor (from ETK)
TRG - fuel level sensor (from ETK)
TRI - Technical Reference Information (also SBT)
TRS - battery isolation Switch
TSD - Torsional vibration dampener (from ETK)
TSH - door lock Heating
TSZI - Transistorized coil Ignition system (from ETK)
TU - Technical Update (as in M50tu)
TXD - Transmitting Diagnosis line
U-batt - Battery voltage
U-vers - supply voltage
UERSS - rollover bar (from ETK)
URS - rollover protection System
USIS - Ultrasonic passenger compartment Sensor
V - "front" (Vorn)
V - vehicle road speed
VA - front Axle (from ETK)
VAT - front axle support (from ETK)
VANOS - Variable camshaft timing
VEP - distributor-type injection Pump (from ETK)
VID - VIDeo module
VL - full load (wide open throttle)
VSD - front muffler (from ETK)
VVT – Valve tronic
WBG - hazard warning switch (from ETK)
WIM - Wiper control Module
WK - torque converter lock-up clutch
WSS – Wind Shield (from ETK)
WT – Valve tronic control unit
Z - "central" (Zentrum)
ZAB - ignition fade-out (reduction)
ZAE - central Airbag Electronics
ZAS - ignition starter switch (from ETK)
ZGM - central Gateway Module
ZK - cylinder head (from ETK)
ZKE - central body Electronics
ZKH - cylinder head cover (from ETK)
ZMS - dual-Mass flywheel (from ETK)
ZV - central locking system
ZS - central lock (from ETK)
ZSD - center muffler (from ETK)
ZV - central locking system (from ETK)
ZVM - central locking Module
ZWD - idle control valve
zrodlo: http://www.bmw-diag.pl/showthread.php?tid=5
  • 8 miesięcy temu...
Jesli można wkleje to z tłumaczeniem które znalazłem w sieci
Słownik terminów i skrótów BMW
A - processed vehicle speed signal - Przetworzony sygnał prędkości pojazdu
A - “out” (Aus) - "Out" (Aus)
AB - Airbag AB - Airbag
ABL - Brake system warning Lamp (2 color) ABL - Brake System ostrzegania lampy (2 kolory)
ABS - Anti-lock Braking System—-Antiblockiersystem ABS - zapobiegający blokowaniu kół podczas hamowania - Antiblockiersystem
AC - Air Conditioning (from ETK) AC - klimatyzacja (od ETK)
ACC - Active Cruise Control ACC - Active Cruise Control
ACS - Active Comfort Seats ACS - Active komfortowe fotele
ADB(X) - Automatic Differential Braking ADB (X) - Automatic Differential hamowania
ADS - engine intake air control ADS - wlot powietrza sterowania silnika
ADV - windshield wiper pressure control—-Anpressdruckverstellung ADV - wycieraczki przedniej szyby kontroli ciśnienia - Anpressdruckverstellung
AEGS - Automatic Electronic Gearbox Control (also EGS) AEG'ów - Automatyczna skrzynia biegów Electronic Control (także EGS)
AFM - Air Flow Meter—-Luftmengenmesser AFM - przepływomierz powietrza - Luftmengenmesser
AGD - suction silencer (from ETK)—-Ansauggeraeuschdaempfer tłumik ssania (z ETK) - - AGD Ansauggeraeuschdaempfer
AGR - emission reduction AGR - redukcji emisji
AGS - Adaptive transmission control—-adaptive Getriebesteuerung AGS - Adaptive kontroli transmisji - adaptacyjne Getriebesteuerung
AG - Automatic Gearbox (transmission)—-automatisches Getriebe AG - Automatyczna skrzynia biegów (skrzynia biegów) - automatisches Getriebe
AHK - Active rear-axle Kinematics AHK - Active tylnej osi Kinematyka
AHK - trailer hitch (from ETK)—-Anhaengerkupplung hak holowniczy (z ETK) - - AHK Anhaengerkupplung
AHM - trailer Module (not for US models) AHM - Moduł przyczepy (nie w modelach USA)
AHPS - Advanced HPS AHPS - Advanced HPS
AIC - Automatic Interval Control (rain sensor) AIC - Automatyczne Interval Control (czujnik deszczu)
AKF - activated carbon canister (from ETK) AKF - aktywny zbiornika z węglem (z ETK)
AKS - Active head restraint AKS - Aktywny zagłówek
AKS - pressure regulating device (from ETK) Urządzenie regulacji ciśnienia (z ETK) - AKS
ALC - Automatic Light Control ALC - Automatyczna migawka
ALR - Automatic Lamp Range Adjustment ALR - Automatyczna regulacja zasięgu lampy
AMM - Air Mass Meter—-Luftmassenmesser AMM - miernika masy powietrza - Luftmassenmesser
AMP - radio system AMPlifier AMP - wzmacniacz radiowy system
ARI - car radio information system (from ETK) ARI - system informacji radia samochodowego (z ETK)
ARS - Active Roll Stabilization ARS - Aktywna stabilizacja Roll
ASC - All Season traction ASC - All Season trakcji
ASC-EZA - ASC w/ engine timing and injection intervention ASC-EZA - w ASC / rozrządu i interwencji wstrzykiwań
ASC+T - ASC+ Traction control ASC + T - ASC + kontrola trakcji
ASK - Audio System controller (Kontroller) ASK - Audio System sterowania (Kontroller)
ASR - self starter block relay (from ETK) ASR - przekaźnik rozrusznika własny blok (z ETK)
AST - Automatic Slip control (marketing term) AST - automatyczne Slip kontroli (termin marketingowy)
AT - remanufactured part (from ETK) AT - regenerowanych części (z ETK)
AT - Antenna (from ETK) AT - Antena (z ETK)
ATF - Automatic Transmission Fluid (from ETK) ATF - Automatic Transmission Fluid (z ETK)
ATL - exhaust gas turbo charger (from ETK)—-Abgasturbolader ATL - spalin turbosprężarki (z ETK) - Abgasturbolader
AUC - Automatic air recirculation AUC - Automatyczne recyrkulacji powietrza
AUT - AUTomatic transmission (from ETK) AUT - automatyczna skrzynia biegów (z ETK)
AVT - Antenna amplifier Tuner AVT - Wzmacniacz Tuner antenowy
AZD - tightening torque specifications (in TIS) AZD - zaostrzenie specyfikacji momentu obrotowego (w TIS)
A/D – Analog/Digital A / D - Analog / Digital
B - Benzene (gasoline)—-Benzin B - Benzen (benzyna) - Benzin
BAT - BATtery (from ETK) BAT - baterii (z ETK)
BC - Board Computer BC - komputer pokladowy
BC1 - Body Controller 1 Body Controller 1 - BC1
BL - Brake Light (from ETK)—-Bremslicht BL - Brake Light (z ETK) - Bremslicht
BLS - Brake Light Switch—-Bremslichtschalter Brake Light Switch - - BLS Bremslichtschalter
Bluetooth - A wireless interconnection technology that automatically recognizes and communicates with components (such as cell phones, headsets and computing devices) when brought into close proximity (generally 30 feet or less). Bluetooth - technologia bezprzewodowa połączeń, które automatycznie rozpoznaje i komunikuje się z komponentów (takich jak telefony komórkowe, zestawy słuchawkowe i urządzeń komputerowych), gdy wejdą w bliskiej odległości (zwykle 30 metrów lub mniej).
BMBT - Board Monitor BMBT - Monitor Board
BS - Block diagram BS - Schemat blokowy
BST - Battery Safety Terminal BST - Terminal Bezpieczeństwo baterii
BVA - Brake pad wear indicator (from ETK)—-Bremsbelagverschleissanzeiger BVA - kłódek wskaźnik zużycia (z ETK) - Bremsbelagverschleissanzeiger
BZM - center console control center BZM - centrum sterowania konsoli centralnej
BZMF - center console control center, rear BZMF - centrum sterowania konsoli centralnej, tylnych
CAN – Controller Area Network (Multiple ECU Controller) Controller Area Network (Multiple Controller ECU) - CAN
CAN-Bus - Controller Area Network (bus) CAN-Bus - Area Network Controller (autobus)
CANH-Bus - CAN bus, High Canh-Bus - CAN High
CANL-Bus - CAN bus, Low CANL-Bus - CAN Low
CANP - fuel tank ventilation valve CANP - zbiornik paliwa zawór wentylacji
CAS - Car Access System CAS - System Access samochodów
CBC - Corner Braking Control CBC - kontrola hamowania Corner
CBS - Condition Based Service CBS - Condition Based Service
CCM - Check Control Module CCM - Moduł kontrolny
CD - Control Display CD - Display Control
CDC - Compact Disk Changer CDC - Compact Disk Changer
CDS - CD player (from ETK) CDS - odtwarzacz CD (z ETK)
CEL - CELsius (from ETK) CEL - C (z ETK)
CIM - Chassis Integration Module CIM - moduł integracji Chassis
CO - Carbon monOxide (from ETK) CO - tlenek węgla (z ETK)
COMBI – Electronic Instrument Cluster COMBI - Electronic Instrument Cluster
CON - CONtroller CON - Kontroler
CU - Copper (from ETK)—-Kupfer CU - Miedź (z ETK) - Kupfer
CVM - Convertible top Module CVM - dach Module
CVT - Constantly Variable Transmission CVT - Ciągle Variable Transmission
CW - drag coefficient (from ETK)—-Luftwiderstandsbeiwert CW - Współczynnik oporu powietrza (z ETK) - Luftwiderstandsbeiwert
CWP - Cold Weather Package CWP - Cold Weather pakietu
D1 - Xenon light/ gas discharge (from ETK) D1 - światła Xenon / wyładowcze (z ETK)
D-Bus - Diagnosis bus (same as TXD) D-Bus - autobus Diagnoza (tak samo jak TXD)
DBC - Dynamic Brake Control DBC - układ dynamicznej kontroli hamowania
DBS - Dynamic Braking System DBS - System hamowania dynamicznego
DCS - Dealer Communication System DCS - System komunikacji Dealer
DE – Diagnostic Unit—-Diagnoseeinheit DE - Diagnostic Unit - Diagnoseeinheit
DD - Dynamic motor Drive DD - Dynamiczny silnik Drive
DDE - Digital Diesel Electronics DDE - Digital Electronics Diesel
DIN - German industrial standards DIN - Niemiecki standardów przemysłowych
DIS - Diagnosis and Information System DIS - System diagnostyczny i Informacji
DISA - Differential air intake control DISA - Regulacja różnicy wlotu powietrza
DIVA - continuously variable length intake runners DIVA - bezstopniowa biegaczy spożycia długość
DK - throttle housing/valve—-Drosselklappe obudowy przepustnicy / zawór - - DK Drosselklappe
DKB - throttle w/ brake intervention w przepustnicy / interwencji hamulca - DKB
DKE – Throttle Increase DKE - Zwiększenie Throttle
DKI - throttle position DKI - położenie przepustnicy
DKR - throttle reduction DKR - zmniejszenie przepustnicy
DKT - throttle position signal DKT - sygnał położenia przepustnicy
DKV - preset throttle position value DKV - zadana położenia przepustnicy
DME - Digital Motor Electronics DME - Digital Electronics Motor
DM-TL - Diagnostic Module Tank Leakage DM-TL - moduł diagnostyczny szczelności zbiornika
DOHC - Double Over Head Camshafts (from ETK)—-doppelte obenliegende Nockenwelle DOHC - Double Over Head rozrządu (z ETK) - Doppelte obenliegende Nockenwelle
DS - gasket set (from ETK)—-Dichtungssatz zestaw uszczelek (z ETK) - - DS Dichtungssatz
DSC - Dynamic Stability Control DSC - układ dynamicznej kontroli stabilności
DSP - Digital Sound Processing DSP - Digital Sound Processing
DTC - Diagnostic Trouble Code (SAE) DTC - Diagnostic Trouble Code (SAE)
DTC - Dynamic Traction Control DTC - układ dynamicznej kontroli trakcji
DWA - theft deterrent system—-Diebstahlwarnanlage DWA - system złodziei - Diebstahlwarnanlage
DWS - tire pressure Warning System—-Druckwarnsystem DWS - ciśnienie w oponach Warning System - Druckwarnsystem
DZM - revolution counter (from ETK)—-Drehzahlmesser obrotomierz (z ETK) - - DZM Drehzahlmesser
E - “in” (Ein) E - "w" (EIN)
EBA - EinBau Anleitung (translated Installation Instructions). EBA - Einbau Anleitung (przetłumaczone Instrukcja instalacji). This is a CD-ROM with installation instructions for various options and upgrades. To jest CD-ROM z instrukcją instalacji dla różnych opcji i ulepszeń.
EBV - Electronic Brake force proportioning—-elektronisches Bremsventil EBV - Electronic Brake dozowania siły - Elektronisches Bremsventil
ECE - European market version (from ETK) ECE - wersja europejska w rynku (z ETK)
ECM - Engine Control Module (SAE term) ECM - Engine Control Module (termin SAE)
ECU - Electronic Control Unit ECU - Electronic Control Unit
EDC - Electronic Damper Control (from ETK) EDC - Electronic Damper Control (z ETK)
EDR - Electronic throttle control—-elektronische Drehzahlregelung Elektroniczne sterowanie przepustnicą - - EDR Elektronische Drehzahlregelung
E-KAT - Electrically heated catalytic converter—-beheizter KAT E-KAT - Elektrycznie ogrzewana katalizator - beheizter KAT
EZA - see ASC-EZA EZA - patrz ASC-EZA
ECO - Controller for I-Drive system ECO - Kontroler systemu i-Drive
EDC - Electronic Dampening Control—-elektronische Daempferkontrolle EDC - Electronic Control nawilżający - elektronische Daempferkontrolle
EDC-K - Electronic Dampening Control - Continuous EDC-K - Electronic Control nawilżający - Continuous
EDK - Electronic throttle valve—-elektronische Drosselklappe przepustnica elektroniczna - - EDK elektronische Drosselklappe
EDS - pressure regulator—-Druckspeicher regulator ciśnienia - - EDS Druckspeicher
EFH - Electric window lifter (from ETK)—-elektrische Fensterheber podnośnik okna elektryczne (z ETK) - - EFH elektrische Fensterheber
EGS - Electronic transmission control—-elektronische Getriebesteuerung kontroli transmisji Electronic - - EGS Elektronische Getriebesteuerung
EH - Electronic-Hydraulic EH - elektroniczno-hydrauliczne
EHC - Electronic Height Control EHC - Electronic Control Wysokość
EKM - Electronic body Module—-elektronisches Karosserie Modul EKM - Electronic ciała Module - Elektronisches Karosserie Modul
EKP - Electric fuel Pump—-elektrische Kraftstoffpumpe EKP - elektryczne pompy paliwa - elektrische Kraftstoffpumpe
ELV - Electronic steering lock—-elektronische Lenkradverriegelung blokada kierownicy Electronic - - ELV elektronische Lenkradverriegelung
EM - Electro-Mechanical—-elektro-mechanisch EM - Electro-Mechanical - elektro-mechanisch
EMF - Electro-Mechanical parking brake—-elektro-mechanische Fussbremse EMF - Electro-Mechanical hamulec postojowy - elektro-mechanische Fussbremse
EML - Electronic Motor Load regulation—-Elektronische Motorlastregelung EML - Electronic Załaduj rozporządzenia Motor - Elektronische Motorlastregelung
EMV - Electro-Magnetic sensitivity (from ETK)—elektromagnetische Vertraeglichkeit EMV - Electro-Magnetic czułości (od ETK)-elektromagnetische Vertraeglichkeit
EO - component location—-Einbauort EO - składnik location - Einbauort
EPC - Electronic Parts Catalog (also ETK) EPC - Electronic Parts Catalog (również ETK)
EPROM - Erasable/ Programmable chip Memory (from ETK) EPROM - Żywotność / Programowalny układ pamięci (z ETK)
ETK - Electronic parts catalog (also EPC)—-Ersatzteilkatalog ETK - Electronic Katalog części (także EPC) - Ersatzteilkatalog
ETM - Electrical Troubleshooting Manual ETM - Elektryczne Ręczne rozwiązywanie problemów
ESS - Electronic anti-theft device—-Elektronisches Sicherheits System ESS - elektroniczne urządzenie zabezpieczające przed kradzieżą - Elektronisches Sicherheits System
EV - injection Valve—-Einspritzventil EV - wtrysk Valve - Einspritzventil
EWS - Electronic drive-away protection—-Elektronische Wegfahrsperre EWS - Electronic drive-od ochrony - Elektronische immobiliser
FB - Function description—-Funktionsbeschreibung FB - Opis funkcji - Funktionsbeschreibung
FBC - Fading Brake Control FBC - Fading Brake Control
FBD - remote control services—-Fernbedienung FBD - usługi zdalnego sterowania - Fernbedienung
FBZV - radio frequency locking system FBZV - system blokady częstotliwości radiowej
FGR – Vehicle Speed Control (Cruise Control)—-Fahrzeuggesxchwindi FGR - Kontrola prędkości pojazdu (Cruise Control) - Fahrzeuggesxchwindi
FH - window lifter—-Fensterheber podnośnik okna - - FH Fensterheber
FHK - rear Heater/ air conditioner FHK - z tyłu grzejnika / klimatyzatora
FLC - automatic Light Control FLC - Automatyczna migawka
FRU - Flat Rate Unit FRU - Flat Rate Unit
FS – Crash Sensor FS - Crash Sensor
FZV - central lock receiver FZV - centralny zamek odbiornik
GAL - speed dependent sound volume—-geschwindigkeitsabhaengige Lautstaerkeregelung GAL - zależne od prędkości dźwięku pojemność - geschwindigkeitsabhaengige Lautstaerkeregelung
GM - General Module—-Grundmodul GM - General Module - Grundmodul
GMR - yaw moment control—-Giermomentregelung GMR - odchylenie kontroli moment - Giermomentregelung
GPS - Global Positioning System GPS - Global Positioning System
GRII - cruise control—-Geschwindigkeitsregelung II (Tempomat) GRII - tempomat - Geschwindigkeitsregelung II (tempomat)
GRS - rotation Rate Sensor GRS - obrót czujnika
GS – Belt Tensioner GS - napinacz paska
GWK - torque converter lock-up control przemiennik momentu obrotowego lock-up kontroli - GWK
H - “rear” (Hinten) H - "tył" (hinten)
H2 - Xenon headlights H2 - reflektory ksenonowe
HA - rear Axle (from ETK)—-Hinterachse HA - tylnej osi (z ETK) - Hinterachse
HC – Hydro Carbon HC - Hydro Carbon
HD - Heavy Duty (from ETK) HD - Heavy Duty (z ETK)
HDC - Hill Decent Control HDC - Hill Godna Control
HFM - Hot Film air mass Meter—-Heissfilmluftmengenmesser HFM - Hot Film masy powietrza Miernik - Heissfilmluftmengenmesser
HG - manual Gearbox (transmission)—-Handschaltgetriebe HG - ręczny Skrzynia biegów (skrzynia biegów) - Handschaltgetriebe
HKL - Hydraulic trunk lid Lift—-hydraulischer Kofferraumdeckellifter HKL - pokrywa bagażnika hydrauliczne Lift - hydraulischer Kofferraumdeckellifter
HLM – Hot Wire Air Mass Meter—-Heissdrahtluftmengenmesser HLM - Hot Air Wire Meter Mass - Heissdrahtluftmengenmesser
HPS - Head Protection System HPS - System Ochrony Head
HR - Heater control (from ETK)—-Heizungsregelung HR - ogrzewanie kontroli (z ETK) - Heizungsregelung
HVA - Hydraulic Valve Adjuster (from ETK) HVA - Hydraulic Valve (Regulacja z ETK)
Hz – Hertz (Cycle) Hz - Hertz (cykl)
I-Bus - Information bus I-Bus - autobus informacji
IB - Interior lighting control signal IB - Oświetlenie wnętrz sygnału sterującego
IHKA - automatic Heating and A/C IHKA - automatyczne ogrzewanie i A / C
IHKAF - IHKA w/ micro filter IHKAF - IHKA w / mikrofiltr
IHKR - regulated Heating and A/C—-Integrierte Heizungs-Klimaregler IHKR - regulowane ogrzewanie i A / C - integrierte Heizungs-Klimaregler
IHKRF - IHKR w/ micro filter IHKRF - IHKR w / mikrofiltr
IHKS - standard Heating and A/C—-Integrierte Heizungs-Klimasteuerung IHKS - standard Ogrzewanie i A / C - integrierte Heizungs-Klimasteuerung
IHPD - Internal High Pressure Deformation IHPD - Internal High Pressure deformacji
IHR - Integrated Heater control (from ETK)—-integrierte Heizungsregelung IHR - Zintegrowany podgrzewacz kontroli (z ETK) - integrierte Heizungsregelung
IKE - Instrument cluster Electronics IKE - Instrument cluster Electronics
ILH - Interior Lighting, rear—-Innenlicht, hinten ILH - Oświetlenie wewnętrzne, z tyłu - Innenlicht, hinten
ILV - Interior Lighting, front—-Innenlicht, vorne ILV - Oświetlenie wewnętrzne z przodu - Innenlicht, vorne
IMS - Instant Mobility System (from ETK) IMS - Instant Mobility System (z ETK)
IR – Infrared IR - podczerwień
IRS – Infrared Locking System IRS - Infrared System blokady
ISC – Idle Speed Control ISC - Idle Speed Control
ISIS - Intelligent Safety Integration System ISIS - Inteligentny System Bezpieczeństwa Integracji
ISN - Individual Serial Number ISN - indywidualny numer seryjny
ISOFIX - standardized mounts for child restraints ISOFIX - standardowe mocowania dla fotelików dziecięcych
ITS - head airbag assembly/ Inflatable Tubular Structure montaż poduszka powietrzna głowy / nadmuchiwane konstrukcji rurowej - ITS
IVM - Integrated power supply Module—-Integriertes Versorgungsmodul IVM - wbudowany zasilacz, moduł - Integriertes Versorgungsmodul
K-Bus - body bus (Karosserie) K-Bus - autobus ciała (Karosserie)
KAT - catalytic converter—-katalysator KAT - katalizator - katalysator
KATON - converter creating (signal) Katon - kalkulator tworzenia (sygnał)
KD - Kick-Down KD - Kick-Down
KDS - Komputer Service Desk (Translated Computer) A CD-ROM that inlcudes the defect codes and flat rate labor units BMW allows for the warranty repair of defects. KDS - Service Desk Komputer (Tłumaczone Computer) CD-ROM inlcudes kodów usterek i płaskie stawki pracy jednostki BMW pozwala na naprawę gwarancyjną od wad.
KHI - interface for headphones—-Kopfhoererinterface KHI - interfejs do podłączenia słuchawek - Kopfhoererinterface
KL - terminal designation—-Klemme oznaczenie terminal - - KL Klemme
KL15 - run bus (ignition switch run position)—-Klemme 15 KL15 - bieg autobus (zapłon pozycji uruchomić przełącznik) - Klemme 15
KL30 - battery bus (hot at all times)—-Klemme 30 (Dauerplus) KL30 - bus baterii (cały czas gorąco) - Klemme 30 (Dauerplus)
KL31 - ground bus (chassis ground)—-Klemme 31 (Masse) KL31 - bus ziemi (masy obudowy) - Klemme 31 (Masse)
KL50 - start bus (ignition start position)—-Klemme 50 KL50 - bus start (miejsce rozpoczęcia zapłonu) - Klemme 50
KLR - accessory bus KLR - akcesoria autobus
KO - compressor “on” signal KO - sprężarki "na" sygnał
KOMBI - instrument cluster—-Kombiinstrument (Tacho-Drehzahlmesser, usw.) KOMBI - tablica przyrządów - Kombiinstrument (Tacho-Drehzahlmesser, usw.)
KOREL - compressor relay signal Korel - sygnał przekaźnika sprężarki
KR – Contact Ring KR - Ring Kontakt
KSK - Knock Sensor—-Klopfsensor KSK - czujnikiem - Klopfsensor
KVA - fuel consumption signal/value KVA - sygnał zużycia paliwa / wartość
KW - crankshaft—-Kurbelwelle KW - wał korbowy - Kurbelwelle
KW - KiloWatt (from ETK) KW - kilowat (z ETK)
LCM - Lamp Check Module LCM - Moduł Sprawdź Lamp
LDP - Leak Diagnosis Pump LDP - Leak Pump Diagnoza
LEV - Low Emissions Vehicle LEV - Tanie Emisje pojazdów
LEW - Lateral acceleration sensor LEW - czujnik przyspieszenia bocznego
LHD - Left-Hand Drive (from ETK)—-Linkslenker LHD - Left-Hand Drive (z ETK) - Linkslenker
LKM - Lamp control Module—-Lampenkontrollmodul LKM - lampka kontrolna Module - Lampenkontrollmodul
LL - closed throttle—-Leerlauf LL - przepustnica zamknięta - Leerlauf
LM - Light Module—-Lichtmodul LM - Light Module - Lichtmodul
LMM - air flow meter/sensor—-Luftmengenmesser/Luftmassenmesser przepływomierz powietrza / czujnik - - LMM Luftmengenmesser / Luftmassenmesser
LMR - Light alloy wheel—-Leichtmetallrad kół ze stopu lekkiego - - LMR Leichtmetallrad
LRA - vertical headlight aiming—-Leuchtweitenregelung LRA - pionowe światła, mające - Leuchtweitenregelung
LSM - steering column memory—-Lenksauelenmemory LSM - pamięć kolumny kierownicy - Lenksauelenmemory
LSZ - Lamp Switching center LSZ - Lampa Switching Center
LVA - air supply system (for EHC system)—-Luftversorungsaggregat układ zasilania powietrzem (w przypadku systemu EHC) - - LVA Luftversorungsaggregat
LWR - vertical headlight aim control—-Leuchtweitenregelung LWR - pionowe Celem kontroli reflektorów - Leuchtweitenregelung
LWS-5 - steering angle sensor—-Lenkwinkersensor LWS-5 - czujnik kąta kierownicy - Lenkwinkersensor
M-Bus - IHKA/IHKR stepper motor bus M-Bus - IHKA / stepper IHKR AUTOBUSÓW
MAL - center armrest—-Mittelarmlehne podłokietnik - - MAL Mittelarmlehne
MBC - Maximum Brake Control MBC - Maksymalna Kontrola hamowania
MDK - Motorized throttle valve/system przepustnica z napędem / system - MDK
MFL - Multi-Function steering wheel—-Multifunktionslenkrad MFL - Multi-Function kierownicy - Multifunktionslenkrad
MFC - Multi-Function Controller MFC - wielofunkcyjny sterownik
MFU - Multi-Function Clock—-Multifunktionsuhr MFU - Zegar wielofunkcyjny - Multifunktionsuhr
MID - Multi-Information Display MID - Multi-Display informacji
MIL - Malfunction Indicator Lamp (SAE), “check engine” Lamp MIL - Wadliwe lampy (SAE), sprawdzić silnik "Lampa
MIR - Multi-Information Radio MIR - Radio Multi-Information
MMC - Multi-Media Changer MMC - Multi-Media Changer
MoDiC - Mobile Diagnostic Computer MoDiC - Mobile Computer diagnostyczne
MOST-Bus - Media Oriented System Transport bus MOST-Bus - autobus Media Oriented systemu transportu
MRS - Multiple Restraint System—-Mehrfach-Rueckhalte-System MRS - Wiele Restraint System - Mehrfach-Rueckhalte-System
MSR - engine drag torque Regulation—-Motorschleppmomentregelung MSR - moment obrotowy silnika przeciągnij rozporządzenia - Motorschleppmomentregelung
MV - Magnetic Valve (solenoid Valve)—-Magnetventil MV - zawór magnetyczny (zawór) - Magnetventil
n-ab - rotational speed, transmission (rpm)—-Drehzahl der Getriebeabtriebswelle n-ab - prędkość obrotowa, przekazywania (rpm) - der Drehzahl Getriebeabtriebswelle
n-mot - rotational speed, engine (rpm)—-Motordrehzahl n-mot - prędkość obrotowa, silnika (obr / min) - Motordrehzahl
NAVI - Navigation module NAVI - moduł nawigacji
NG - New Generation (as in N73 engine) NG - nowa generacja (jak w N73 silnika)
NG - tilt sensor—-Neigungssensor czujnikiem przechyłu - - NG Neigungssensor
NOX - Nitrogen Oxides/ exhaust gas recirculation (from ETK) NOX - tlenków azotu / układ recyrkulacji spalin (z ETK)
NSD - rear muffler (from ETK)—-Nachschalldaempfer NSD - tylny tłumik (z ETK) - Nachschalldaempfer
NSL - rear fog Lamp (from ETK)—-Nebelschlussleuchte NSL - tylne światło przeciwmgielne (z ETK) - Nebelschlussleuchte
NSW - fog lamp (from ETK)—-Nebellampe światło przeciwmgielne (z ETK) - - NSW Nebellampe
NTC - Negative Temperature Coefficient NTC - ujemnym współczynniku temperaturowym
NW - camshaft (from ETK)—-Nockenwelle NW - rozrządu (z ETK) - Nockenwelle
OBC - On-Board Computer OBC - komputer pokładowy
OBD - On-Board Diagnosis (SAE) OBD - On Board Diagnosis-(SAE)
P/N – Park/Neutral position P / N - Park / stanowisko neutralne
P-Bus - Periphery bus P-Bus - autobus Periphery
PB - Pin assignments—-Pinbelegung PB - Pin zadań - Pinbelegung
PBS - Parts Bulletin System (in TIS) System Biuletyn części (TIS) - PBS
PDC - Park Distance Control PDC - Park Distance Control
PGS - Passive Go System PGS - Passive Go System
PM - Power Module PM - moduł zasilający
PP – Impact Pad PP - Pad wpływu
PTC - Positive Temperature Coefficient PTC - Positive Temperature Coefficient
RLS - Rain-Light Sensor—-regen-Licht-Sensor RLS - Rain-Light Sensor - rege-Licht-Sensor
PWG - Pedal position sensor/ potentiometer—-Pedalwertgeber czujnik położenia pedału / potencjometr - - PWG Pedalwertgeber
RA - Repair instructions (in TIS) RA - instrukcje napraw (w TIS)
RAM – Random Access Memory RAM - Random Access Memory
RAL - Aluminum wheels (from ETK) RAL - aluminiowe felgi (z ETK)
RAL - standard color (from ETK)—-Reichsausschuss-fuer-Lieferbedingungen RAL - kolor (z ETK) - Reichsausschuss-fuer-Lieferbedingungen
RDC - tire pressure Control—-Reifendruckkontrolle RDC - Kontrola ciśnienia w oponach - Reifendruckkontrolle
RDS - Radio Data-broadcast System RDS - Radio Data System-broadcast
RDW - tire pressure Warning—-Reifendruckwarner Uwaga ciśnienie w oponach - - RDW Reifendruckwarner
RHD - Right-Hand Drive (from ETK)—-Rechtslenkung RHD - z prawej strony (z ETK) - Rechtslenkung
RM - Relay Module—-Relaismodul RM - Relay Module - Relaismodul
ROZ - Research Octane rating/ fuel grade (from ETK) ROZ - Badania oktanowej / klasa paliwa (z ETK)
RPA - tire puncture warning (from ETK) przebicie opony ostrzeżenie (z ETK) - RPA
RPS - Rollover Protection System RPS - Rollover Protection System
RS - Repair kit (from ETK) RS - Zestaw naprawczy (z ETK)
RSW - back-up lamp (from ETK)—-Rueckfahrscheinwerfer RSW - back-up lampy (z ETK) - Rueckfahrscheinwerfer
RXD - wake-up Diagnosis line RXD - wake-up line Diagnoza
RZV - direct stationary ignition RZV - bezpośredni zapłon stacjonarnych
SASL - Satellite, A-pillar left SASL - satelitarna, lewym filarze
SASR - Satellite, A-pillar right SASR - satelitarna, filaru prawo
SAV - Sport ACTIVITY Vehicle SAV - Pojazd sport
SB - fuse assignments SB - zadania bezpiecznik
SBE - Seat occupancy detector/sensor—-Sitzbelegungssensor czujnik obecności Seat / czujnik - - SBE Sitzbelegungssensor
SBFH - Seat module, passenger-side rear SBFH - moduł Seat, z tyłu po stronie pasażera
SBSL - Satellite, B-pillar left SBSL - satelitarna, słupek B w lewo
SBSR - Satellite, B-pillar right SBSR - Satellite prawym słupku
SBT - SI techniques/ tech reference information (in TIS) SBT - technik SI / tech informacji referencyjnych (w TIS)
SCA - Soft Close Automatic/Actuator SCA - domykania / siłownika
SD - sliding roof (from ETK) SD - Otwierany dach (z ETK)
SD - silencer/ muffler (from ETK)—-Schalldaempfer SD - tłumik / tłumik (z ETK) - Schalldaempfer
SE - Special Equipment (from ETK) SE - Special Equipment (z ETK)
SES - voice recognition System SES - System rozpoznawania mowy
SFAH - Seat module, driver's side rear SFAH - moduł bezpieczeństwa, kierowcy tyłu
SFZ - Satellite, vehicle center SFZ - satelitarna, centrum pojazdu
SG - control unit SG - jednostka sterująca
SGS - Seat integrated belt System SGS - Seat System zintegrowany pas
SHD - sliding/ lifting roof (from ETK)—-Schiebe-Hubdach SHD - przesuwne / podnoszenia dachu (z ETK) - Schiebe-Hubdach
SHD - Sunroof module (also SHDM) SHD - moduł szyberdach (również SHDM)
SI - Service Information (in TIS) SI - Information Service (w TIS)
SIA - Service Interval system (ver. I, II, III, IV, etc.) SIA - Service Interval system (wersja I, II, III, IV, itp.)
SII - Service Interval Indicator SII - Wskaźnik Service Interval
SIL - SILicon (from ETK) SIL - krzemu (z ETK)
SIM - Safety Information Module SIM - moduł Informacje o bezpieczeństwie
SINE - Siren/tilt sensor SINE - Siren / czujnikiem przechyłu
SKD - Steel sliding roof (from ETK)—-Stahlkurbeldach SKD - Stal Otwierany dach (z ETK) - Stahlkurbeldach
SKHD - Steel sliding/ lifting roof (from ETK) SKHD - Stal przesuwne / podnoszenia dachu (z ETK)
SM - Seat Module SM - Moduł Seat
SM/SPM - Seat/Mirror Memory SM / SPM - Seat / Memory Mirror
SMBF - Seat Module, passenger side SMBF - Seat Module, po stronie pasażera
SMFA - Seat Module, driver's side SMFA - Seat Module, po stronie kierowcy
SMG - Sequential Manual Gearbox—-Sequentielles-Manuelles -Getriebe SMG - Sequential Manual Gearbox - Sequentielles-Manuelles-Getriebe
SP - Schematic SP - Schemat
SRA - headlight/fog light cleaning—-Scheinwerferreinigungsanlage SRA - reflektorów przeciwmgielnych delikatnego czyszczenia - Scheinwerferreinigungsanlage
SRS - Supplementary Restraint System—Sitz-Rueckhaltsystem SRS - Dodatkowe Restraint System-Sitz-Rueckhaltsystem
SSD - Steel sliding roof (from ETK)—-Stahlschiebedach SSD - Stal Otwierany dach (z ETK) - Stahlschiebedach
SSH - Seat Satellite, rear seat SSH - Seat satelitarna, tylne siedzenie
ST - connector views ST - widok złącza
Steptronic - transmission shift control Steptronic - Transmission Control zmiany
STVL - Satellite, left front door—Satellit, Tuer vorne links STVL - satelitarna, lewe przednie drzwi Satellit, Tuer vorne linki
STVR - Satellite, right front door—Satellit, Tuer vorne rechts STVR - satelitarna, prawe przednie drzwi Satellit, Tuer vorne rechts
SVS - Speech processing System—-Sprachverarbeitungssystem SVS - Speech Processing System - Sprachverarbeitungssystem
SWR - headlamp cleaning system (from ETK)—-Scheinwerferreinigungsanlage System czyszczenia reflektorów (z ETK) - - SWR Scheinwerferreinigungsanlage
SWZ - Special tool listings (in TIS)—-Spezialwerkzeug SWZ - specjalne narzędzie aukcji (w TIS) - Spezialwerkzeug
SZL - Switch center, steering column SZL - Centrum Switch, kolumny kierownicy
SZM - central switch center Module SZM - moduł centralny przełącznik centrum
TAGE - door handle Electronics TAGE - klamka Electronics
TCM - Transmission Control Module TCM - Transmission Control Module
TD - engine speed signal (ignition pulse) TD - sygnał prędkości obrotowej silnika (impuls zapłonu)
TD - Technical Data (in TIS) TD - dane techniczne (w TIS)
TDD - Technical Documentation Disk. TDD - Dokumentacja techniczna dysku. Made availble to consumers and dealers by force of the DOT/EPA regulations for servicing the electrical and mechanical components of the emissions replated systems on the cars that are not on the ETM. Made availble dla konsumentów i dealerów życie DOT / EPA przepisów do obsługi elektrycznych i mechanicznych części emisji replated systemy na samochodach, które nie są na ETM.
TE - fuel evaporation control—-Tankentlueftung kontroli parowania paliwa - - TE Tankentlueftung
TEL - TELephone control unit TEL - telefon centrali
TEV - evaporative purge control—-Tankentlueftungsventil TEV - par kontroli purge - Tankentlueftungsventil
THZ - Tandem master cylinder (from ETK)—-Tandemhauptzylinder pompa hamulcowa Tandem (z ETK) - - THz Tandemhauptzylinder
ti - Injector “on” Time (duration)—-transmittierende Injektion (Einspritzung) ti - Injector "na" Time (czas trwania) - transmittierende Injektion (Einspritzung)
TIS - Technical Information System TIS - Technical Information System
TL - part throttle / load signal—-Teillast TL - część przepustnicy / sygnału obciążenia - Teillast
TLEV - Transitional Low Emission Vehicle TLEV - Transitional Low Emission Vehicle
TMBFT - door Module, passenger side TMBFT - drzwi modułu, po stronie pasażera
TMBFTH - door Module, passenger side rear TMBFTH - Moduł drzwi, z tyłu po stronie pasażera
TMFAT - door Module, driver's side TMFAT - Moduł drzwi, po stronie kierowcy
TMFATH - door Module, driver's side rear TMFATH - drzwi Module, kierowcy tyłu
TP - Tandem Pump (from ETK) TP - Tandem pompy (z ETK)
TPS - Throttle Position Switch/Sensor Przełącznik położenia przepustnicy / Czujnik - TPS
TR - engine speed signal (rpm) TR - sygnał prędkości obrotowej silnika (obr / min)
TR - TRansistor (from ETK) TR - tranzystor (z ETK)
TRG - fuel level sensor (from ETK)—-Treibstoffstandgeber czujnik poziomu paliwa (z ETK) - - TRG Treibstoffstandgeber
TRI - Technical Reference Information (also SBT) TRI - Technical Reference Information (również SBT)
TRS - battery isolation Switch TRS - bateria izolacji Switch
TSD - Torsional vibration dampener (from ETK) tłumika drgań skrętnych (z ETK) - TSD
TSB - Technical Service Bulletin TSB - technicznej Service
TSH - door lock Heating—-Tuerschlossheizung TSH - Ogrzewanie drzwi zamek - Tuerschlossheizung
TSZI - Transistorized coil Ignition system (from ETK)—-Transistorspulenzuendung TSZI - System kontroli cewki zapłonowej systemu (z ETK) - Transistorspulenzuendung
TU - Technical Update (as in M50tu) TU - Aktualizacja techniczna (jak w M50tu)
TXD - Transmitting Diagnosis line TXD - przekazujące Diagnoza line
U-batt - Battery voltage—-Batteriespannung U-batt - napięcie akumulatora - Batteriespannung
U-vers - supply voltage—-Spannungsversorgung U-vers - napięcie zasilania - Spannungsversorgung
UERSS - rollover bar (from ETK)—-Ueberrollschutz bar rollover (z ETK) - - UERSS Ueberrollschutz
URS - rollover protection System URS - Rollover Protection System
USIS - Ultrasonic passenger compartment Sensor USIS - czujnik ultradźwiękowy pasażerskiej
V - “front” (Vorn) V - "front" (Vorn)
V - vehicle road speed—-Geschwindigkeit Prędkość pojazdu - - V Geschwindigkeit
VA - front Axle (from ETK)—-Vorderachse VA - przednia oś (od ETK) - Vorderachse
VAT - front axle support (from ETK)—-Vorderachstraeger VAT - przednia oś wsparcia (z ETK) - Vorderachstraeger
VANOS - Variable camshaft timing—-Variable Nockenwellensteuerung VANOS - zmiennych faz rozrządu - Variable Nockenwellensteuerung
VEP - distributor-type injection Pump (from ETK)—-Verteilereinspritzpumpe VEP - dystrybutor typu pompy wtryskowej (z ETK) - Verteilereinspritzpumpe
VID - VIDeo module VID - modułu wideo
VL - full load (wide open throttle)—-Volllast VL - pełnym obciążeniu (szerokie otwarcie przepustnicy) - Volllast
VSD - front muffler (from ETK)—-Vorschalldaempfer VSD - tłumik z przodu (z ETK) - Vorschalldaempfer
VVT – Valve tronic VVT - tronic Valve
WBG - hazard warning switch (from ETK)—-Warnblinkanlage przełącznik awaryjnych (z ETK) - - WBG Warnblinkanlage
WIM - Wiper control Module WIM - Moduł sterowania wycieraczek
WK - torque converter lock-up clutch—-Wandlerueberbrueckungskupplung WK - konwerter momentu obrotowego sprzęgła lock-up - Wandlerueberbrueckungskupplung
WSS – Wind Shield (from ETK)—-Windschutzscheibe WSS - Wind Shield (z ETK) - Windschutzscheibe
WT – Valve tronic control unit WT - Valve elektronicznej jednostki sterującej
Z - “central” (Zentrum) Z - "centralne" (Zentrum)
ZAB - ignition fade-out (reduction) ZAB - zapłon fade-out (redukcja)
ZAE - central Airbag Electronics ZAE - Poduszki powietrzne centralny Electronics
ZAS - ignition starter switch (from ETK)—-Zuend-Anlass-Schalter ZAS - zapłon starter switch (z ETK) - Zuend-Anlass-Schalter
ZGM - central Gateway Module ZGM - centralny moduł Gateway
ZK - cylinder head (from ETK)—-Zylinderkopf ZK - głowicy (z ETK) - Zylinderkopf
ZKE - central body Electronics—-Zentrale Karosserie Elektronik ZKE - centralny organ Electronics - Zentrale Karosserie Elektronik
ZKH - cylinder head cover (from ETK)—-Zylinderkopfhaube ZKH - pokrywę głowicy cylindra (z ETK) - Zylinderkopfhaube
ZMS - dual-Mass flywheel (from ETK)—-Zweimassenschwungrad ZMS - dwumasowe koło zamachowe (z ETK) - Zweimassenschwungrad
ZV - central locking system—-Zentralverriegelung ZV - centralny zamek - Zentralverriegelung
ZS - central lock (from ETK)—-Zentralschluessel ZS - centralny zamek (z ETK) - Zentralschluessel
ZSD - center muffler (from ETK)—-Zentral(mittel)schalldaempfer tłumik centrum (z ETK) - - ZSD Zentral (Mittel) schalldaempfer
ZV - central locking system (from ETK) ZV - centralny zamek (z ETK)
ZVM - central locking Module—-Zentralverriegelungsmodul ZVM - centralny zamek Module - Zentralverriegelungsmodul
ZWD - idle control valve ZWD - zawór biegu jałowego
Sprzedam
