INPA Battery OFF Ignition OFF - już brak pomysłów
Przejrzałem już chyba wszystkie tematy z tym związane i dalej mam problem z podłączeniem się do samochodu
Z czym pracuję:
Interfejs:
http://allegro.pl/bmw-usb-1996-2006-inpa-pl-dis-e46-e90-e39-e60-e61-i2711881197.html
Inpa:
Próbowałem zarówno na 9.0.7 jak i 10.0.4
Konfiguracja portu:
COM 2
Odbiór: 1024
Transmisja: 1024
Opóźnienie:1
Przy instalacji inpy ustawiałem zarówno na ADS jak i OBD i nic.
Pliki EDIABAS.ini i OBD.ini
;EDIABAS 6.4.3 Configuration
[Configuration]
; EcuPath
; Description : ECU file path
; Default = .
EcuPath = C:\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
SimulationPath = C:\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
TracePath = C:\EDIABAS\TRACE
; CodeMapping
; Description : Character mapping file path
; Default = .
;CodeMapping = C:\EDIABAS\BIN\ansi2oem.tab
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0..32767
; Default = 1024
;TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; Default = 0
ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = Trace enabled
; 2 = Trace enabled
; 3 = Trace enabled
; Default = 0
IfhTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
UbattHandling = 1
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
IgnitionHandling = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
TaskPriority = 0
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
LoadWin32 = 1
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
SystemResults = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
RetryComm = 1
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
Simulation = 0
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
Interface = STD:OBD
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : OBD.ini nur benutzt wenn im Windows-Verzeichnis
; Unterstuetzung : WIN3.xx : Nein
; WIN95,98 16-Bit : Ja
; WIN95,98 32-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:FUNK
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Unterstuetzung : WIN95,98 16-Bit : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; Beschreibung : Serieller Pegelwandler (Anschluss an Diagnose-Dose)
; Installation : \EDIABAS\HARDWARE\ADS\ADS32\ADSSETUP (nur fuer WinNT4 noetig)
; INI-Datei : keine
; WIN95,98 32-Bit : Nein
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; Beschreibung : Serieller Pegelwandler (Anschluss direkt an K-Bus oder I-Bus)
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; Beschreibung : Serielles , PCMCIA , PC-Card Interface von Fa. Softing
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; Beschreibung : EDIC-Card C oder EDIC-Card 2 CAN-Interface von Fa. Softing
; INI-Datei : XEDICC.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CANRTTP.INI
; Unterstuetzung : WIN95,98 16-Bit : ?
; WIN95,98 32-Bit : ?
; WIN NT 4.0 : Ja
; WIN XP : ?
; Ansprechpartner: Hr. Jusko
; Telefon : +49-(0)89/382-35891 (Hotline)
; email : FLASH.SERVICE@BMW.DE (Hotline)
; Interface = STD:ADS4MOST
; Beschreibung : Most-Interfaces von Fa. Oasis
; Installation : keine (ausser Installation der Oasis-Karte)
; INI-Datei : ADS4MOST.INI
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Ansprechpart.: Hr. Rowedder
; Telefon : 089 / 382-29159
; email : Michael.Rowedder@bmw.de
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Unterstuetzung : WIN95,98 16-Bit : Nein
; WIN NT 4.0, XP : Ja
; WIN XP : Ja
; Sonderfall : Interface OPPS
; Interface = REMOTE:name
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port)
; WIN XP : Ja
; NetworkProtocol
; Description : Network protocol
; Default =
NetworkProtocol = TCP
;TCP/IP Configuration
[TCP]
; RemoteHost
; Description : server address/name
; Default =
RemoteHost = 192.168.68.1
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Default =
Port = 6801
;TimeoutConnect
; Description : Timeout for establishing the connection
; Default = 5000
TimeoutConnect = 2000
;TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
TimeoutReceive = 2000
;TimeoutFunction
; Description : Timeout for a long function
; Default = 59000
TimeoutFunction = 10000
;DisconnectOnApiEnd
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
;DisconnectOnApiEnd = 1
;InitCmd
; Description : Initialization command (normally for OPPS)
; Default =
;InitCmd0 = FE,04,00,03,01
;InitCmd1 = FD,05,00,03,01
; End Of File EDIABAS.ini
[OBD]
Port=Com1
TRACELEVEL = 0x00000000
HARDWARE=OBD
RETRY=ON
MODE=NORMAL
;OBD-Stecker OBD
;OBD-Stecker am USB->Seriell-Adapter USB
;alte ADS-Hardware ADS
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendData
;[uNIT_x] x = A, B, ...,Y, Z, 0, 1, .., 8, 9
;Port = Com1 COM1 .. COM9
;TRACELEVEL = 0x00000000 0x00000000 .. 0xFFFFFFFF
;RETRY = OFF OFF, ON
;MODE=NORMAL NORMAL, KBUS
;HARDWARE=OBD OBD, USB, ADS
[uNIT_A]
Port=Com1
Hardware=OBD
RETRY=ON
MODE=NORMAL
[uNIT_B]
Port=Com2
Hardware=OBD
[uNIT_C]
Port=Com3
Hardware=OBD
[uNIT_D]
Port=Com4
Hardware=OBD
[uNIT_E]
Port=Com5
Hardware=OBD
[uNIT_F]
Port=Com6
Hardware=OBD
[uNIT_G]
Port=Com7
Hardware=OBD
[uNIT_H]
Port=Com8
Hardware=OBD
[uNIT_I]
Port=Com9
Hardware=OBD
[uNIT_J]
Port=Com10
Hardware=OBD
[uNIT_K]
Port=Com11
Hardware=OBD
[uNIT_L]
Port=Com12
Hardware=OBD
[uNIT_M]
Port=Com13
Hardware=OBD
[uNIT_N]
Port=Com14
Hardware=OBD
[uNIT_O]
Port=Com15
Hardware=OBD
System XP + SP3
Interfejs zainstalował mi się w Kontrolerach uniwersalnej magistrali szeregowej jako USB Serial Converter tak ma być?
Nie mogę się połączyć, cały czas mam ignition i battery OFF, żadne testy nie chodzą.
Skończyły mi się pomysły i prosiłbym o pomoc.
Daj tak:
; RemoteHost
; Default =
RemoteHost = 192.168.68.30
; Port
; Default =
Port = 6801
a w obd.ini w zależnośći od Portu Com1 lub Com2
[OBD]
Port=Com1
Hardware=OBD
RETRY=ON
UBATT=OFF
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
Port=Com3
Hardware=OBD
[uNIT_C]
Port=Com4
Hardware=OBD
[uNIT_D]
Port=Com5
Hardware=OBD
[uNIT_E]
Port=Com6
Hardware=OBD
[uNIT_F]
Port=Com7
Hardware=OBD
[uNIT_G]
Port=Com8
Hardware=OBD
[uNIT_H]
Port=Com9
Hardware=OBD
[uNIT_I]
Port=Com10
Hardware=OBD
[uNIT_J]
Port=Com11
Hardware=OBD
[uNIT_K]
Port=Com12
Hardware=OBD
[uNIT_L]
Port=Com13
Hardware=OBD
[uNIT_M]
Port=Com14
Hardware=OBD
jakie instalowałeś sterownika do kabelka od nich czyli te co ci podesłali z kabelkiem czy nowsze z netu , miałem ten sam problem po zainstalowaniu nowszych sterowników wszystko śmiga aż miło
no proszę, a skąd miałęś taki info ? :mrgreen:
wwo_j
masz racje kolego podałeś mi namiar na stery , ale dostałem cała paczke od innego kolegi z forum wraz z inpą
Ja mam problem z połączeniem z autem jak mam uruchomiony program w tle do łączenia z telefonem.
Jak idę do auta wyłączam w menedżerze zadań niepotrzebne zadania uruchomione przez użytkownika i tu "twój login do kompa",
Po wyłączeniu powyższego programu Battery On i Ignition On, przed wyłączeniem 2x off.
Pozdrówka
dziś ci nie powiem, bo laptopa nie mam przy sobie. Jutro porównam pliki i dam znać
ediabas.ini
;EDIABAS 6.4.7 Configuration
[Configuration]
; EcuPath
;       Default     =   .
EcuPath          =C:\EDIABAS\ECU
; SimulationPath
;       Default     =   .
SimulationPath   =C:\EDIABAS\SIMULATION
; TracePath
;       Default     =   .
TracePath        =C:\EDIABAS\TRACE
; CodeMapping
;       Default     =   .
; TraceSize
;       Value       :   0..32767
;       Default     =   1024
TraceSize        = 32767
; ApiTrace
;                       1  = User trace
;       Default     =   0
ApiTrace         =0
; IfhTrace
;                       1  = User trace
;                       2  = User trace + interface
;                       3  = User trace + interface + time stamp
;       Default     =   0
IfhTrace         =0
; IfhnTrace
;       Description :   Enable/Disable IFH network trace (with XREMOTE)
;                       1  = User trace
;       Default     =   0
;IfhnTrace        = 0
; SystemTraceSys
;                       Trace levels 1..7
;       Default     =   0
SystemTraceSys   = 0
; SystemTraceBip
;                       Trace levels 1..7
;       Default     =   0
SystemTraceBip   = 0
; SystemTraceIfh
;                       Trace levels 1..7
;       Default     =   0
SystemTraceIfh   = 0
; SystemTraceNet
;                       Trace levels 1..7
;       Default     =   0
SystemTraceNet   = 0
; BipDebugLevel
;       Value       :   0..32767
;       Default     =   0
BipDebugLevel    = 0
; UbattHandling
;       Default     =   1
UbattHandling    = 0
; IgnitionHandling
;       Default     =   1
IgnitionHandling = 0
; ClampHandling
;       Description :   automatic check of clamps for Ubatt and Ignition
;       Value       :   0  = no automatic clamp check with send_and_receive
;                       1  = automatic clamp check with send_and_receive
;       Default     =   1
;ClampHandling    = 1
; TaskPriority
;       Default     =   0
TaskPriority     = 0
; LoadWin32
;LoadWin32        = 0
; SystemResults
;       Default     =   1
SystemResults    = 1
; RetryComm
;       Default     =   1
RetryComm        = 1
; Simulation
;       Default     =   0
Simulation       = 0
; Interface
;       Default     =   STD:OBD
Interface        =STD:OBD
; INI-Datei      : Suchreihenfolge analog zu EDIABAS.ini
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = ADS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = KBUS
; INI-Datei      : keine
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDIC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Interface      = EDICC
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; Beschreibung   : PCMCIA CAN-Interface CanCardX/XL von Fa. Vector
; INI-Datei      : CAN32.INI
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
;                  WIN NT 4.0       : Ja
;                  WIN XP           : Ja
; INI-Datei      : keine
;                  WIN XP           : Ja
;                  WIN XP           : Ja
; NetworkProtocol
;       Default     =
[TCP]
; RemoteHost
;       Default     =
; Port
;       Default     =
Port                 = 6801
;TimeoutConnect
;       Default     =   5000
;TimeoutReceive
;       Default     =   5000
;TimeoutFunction
;       Default     =   59000
;DisconnectOnApiEnd
;       Default     =   0
;InitCmd<n>
;       Description :   Initialization command <n> (normally for OPPS)
;       Default     =
obd.ini
[OBD]
Port=Com1
Hardware=OBD
RETRY=ON
UBATT=OFF
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
[UNIT_A]
Port=Com2
Hardware=OBD
[UNIT_B]
Port=Com3
Hardware=OBD
[UNIT_C]
Port=Com4
Hardware=OBD
[UNIT_D]
Port=Com5
Hardware=OBD
[UNIT_E]
Port=Com6
Hardware=OBD
[UNIT_F]
Port=Com7
Hardware=OBD
[UNIT_G]
Port=Com8
Hardware=OBD
[UNIT_H]
Port=Com9
Hardware=OBD
[UNIT_I]
Port=Com10
Hardware=OBD
[UNIT_J]
Port=Com11
Hardware=OBD
[UNIT_K]
Port=Com12
Hardware=OBD
[UNIT_L]
Port=Com13
Hardware=OBD
[UNIT_M]
Port=Com14
Hardware=OBD
[UNIT_N]
Port=Com15
Hardware=OBD
[UNIT_O]
Port=Com16
Hardware=OBD
zobacz na tych, i daj znać
Panie i Panowie. Mam ultimate evolt cable solution do naszych ultimate driving machine :).
Czyli, kto ma kabel od EVOLTA jest szczesciarzem - jak sie go dobrze skonfiguruje, to faktycznie wykrywa zaplon a nie tylko ma zwarte piny na stale!
Co nalezy zrobic (instrukcja dla Win Xp).
1) Po otrzymaniu kabla nie instalowac starych sterow od nich!
2*) Jesli sie je zainstalowalo to sciagamy http://www.ftdichip.com/Support/Utilities/CDMUninstaller_v1.4.zip i usuwamy je
3) Sciagamy sterowniki najnowsze ze strony producenta chipu http://www.ftdichip.com/Drivers/VCP.htm
4) Ustawiamy w ustawieniach emulatora COM, zeby byl COM1, Latency timer 1 etc (tak jak w kazdym manualy do inpy. np od nerwusa)
5) W EDIABAS/BIN szukamy OBD.ini i zmieniamy w pierwszej linijce (DLA COM=1) HARDWARE=USB zamiast OBD. Oprocz tego dopisujemy UBATT=OFF.
6) Plik zostaje w tym katalogu, ale kopiujemy go tez do katalogu Windows (bezposrednio)
7) Teraz kabel pokazuje zawsze BATT ON ale ma detekcje INGITION!
Mialem ten problem co wy i zrezygnowany zaczalem kombinowac. To co powyzej sprawilo, ze kabel dziala super!
Powodzenia! :cool2:
No widzisz, a mi pomoglo ;). Albo to, albo wgranie do katalogu windowsa dodatkowo pliku OBD.ini. Jak nie dalem hardware na USB (albo to przegranie OBD.ini?) to nie czytal mi stanu Ignition (sprawdze w wolnej chwili, ale to USB jako hardware nie przeszkadza). Teraz mam w pelni aktywne czytanie. Przed przekreceniem zaplanu tylko BATT ON a po IGNITION ON :8) .
Witam :)
Panowie powiedzcie mi czy kontrolka battery powinna świecić sie po podpięciu samego kabla czy dopiero gdy kabel jest podłączony do samochodu? mam kabel evolta zrobilem wszystko wg powizszej instrukcji i nie dziala :(
Jak masz porządny kabel to bateria świeci się jak podepniesz dopiero pod auto, a zapłon jak dasz zapłon.
Ale sprzedają fejsy które na stałe maja zapłon i baterie lub sama baterie przez modyfikacje obd.ini.
We wszystkich przypadkach jak fejs jest ok powinno działać.
Witam, ludzie pomóżcie, bo już jestem na skraju wyczerpania nerwowego :mad2: A więc opiszę o co chodzi. Mam zainstalowaną inpę i disa gotowego od trandolfa na vmware i odpalam inpe włącza się normalnie ale jest battery off i ingnition off nawet po podłączeniu do samochodu ;/ Więc postanowiłem ,że zainstaluje sam od nowa wszystko, zainstalowałem inpe (oczywiście na vwmare, na czystym xp), najnowsze stery do kabla (kabel obd od e-volta), skonfigurowałem z com1, zmienna środowiskowa dodana i co? nadal to samo battery off i ingnition off :mad2:
Dodam jeszcze, że próbowałem wyżej wymienionych wskazówek i nic... Ma ktoś jakiś pomysł na to? Bo jeszcze trochę i nie wytrzymam, laptop będzie latał po podwórku.. :evil:
Niżej wklejam pliki EDIABAS.ini i OBD.ini
[Configuration]
; EcuPath
; Default = .
; SimulationPath
; Default = .
; TracePath
; Default = .
; CodeMapping
; Default = .
; TraceSize
; Value : 0..32767
; Default = 1024
TraceSize = 32767
; ApiTrace
; 1 = User trace
; Default = 0
ApiTrace =0
; IfhTrace
; 1 = User trace
; Default = 0
IfhTrace =0
; IfhnTrace
; 1 = User trace
; Default = 0
;IfhnTrace = 0
; SystemTraceSys
; Trace levels 1..7
; Default = 0
SystemTraceSys = 0
; SystemTraceBip
; Trace levels 1..7
; Default = 0
SystemTraceBip = 0
; SystemTraceIfh
; Trace levels 1..7
; Default = 0
SystemTraceIfh = 0
; SystemTraceNet
; Trace levels 1..7
; Default = 0
SystemTraceNet = 0
; BipDebugLevel
; Value : 0..32767
; Default = 0
BipDebugLevel = 0
; UbattHandling
; Default = 1
UbattHandling = 0
; IgnitionHandling
; Default = 1
; ClampHandling
; Default = 1
;ClampHandling = 1
; TaskPriority
; Default = 0
TaskPriority = 0
; LoadWin32
;LoadWin32 = 0
; SystemResults
; Default = 1
SystemResults = 1
; RetryComm
; Default = 1
RetryComm = 1
; Simulation
; Default = 0
Simulation = 0
; Interface
; Default = STD:OBD
Interface =STD:OBD
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = ADS
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = KBUS
; INI-Datei : keine
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDIC
; WIN NT 4.0 : Ja
; WIN XP : Ja
; Interface = EDICC
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; WIN NT 4.0 : Ja
; WIN XP : Ja
; INI-Datei : keine
; WIN XP : Ja
; WIN XP : Ja
; NetworkProtocol
; Default =
[TCP]
; RemoteHost
; Default =
; Port
; Default =
Port = 6801
;TimeoutConnect
; Default = 5000
;TimeoutReceive
; Default = 5000
;TimeoutFunction
; Default = 59000
;DisconnectOnApiEnd
; Default = 0
;InitCmd
; Default =
[OBD]
Port=Com1
Hardware=USB
RETRY=ON
UBATT=OFF
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
[uNIT_A]
Port=Com2
Hardware=OBD
[uNIT_B]
Port=Com3
Hardware=OBD
[uNIT_C]
Port=Com4
Hardware=OBD
[uNIT_D]
Port=Com5
Hardware=OBD
[uNIT_E]
Port=Com6
Hardware=OBD
[uNIT_F]
Port=Com7
Hardware=OBD
[uNIT_G]
Port=Com8
Hardware=OBD
[uNIT_H]
Port=Com9
Hardware=OBD
[uNIT_I]
Port=Com10
Hardware=OBD
[uNIT_J]
Port=Com11
Hardware=OBD
[uNIT_K]
Port=Com12
Hardware=OBD
[uNIT_L]
Port=Com13
Hardware=OBD
[uNIT_M]
Port=Com14
Hardware=OBD
[uNIT_N]
Port=Com15
Hardware=OBD
[uNIT_O]
Port=Com16
Hardware=OBD
